Home Forums Products Plug-Ins Share Blackhole settings/presets between the pedal and VST? Reply To: Share Blackhole settings/presets between the pedal and VST?
#155830
joecozzi
    No, you cannot share presets between the pedal and the VST. They are different in that the plug-in does have an extended range on the Size knob that makes more sense in a production environment; it ranges from -10 to120 versus just 0–100, like the algorithm on Space, H9, and Blackhole. That negative range on the plug-in renders interesting comb filtering sounds that make more sense in a mix.
    They do, however, function and sound almost exactly the same. If you were to stay with the ranges of the pedal (0–100) you can most definitely achieve the same results between the two products.
