Home Forums Products Plug-Ins Generate: (unintended noise) Reply To: Generate: (unintended noise)
#155848
DGillespie
    blacksunhighdesert wrote:
    I love the Generate Synth! Still learning to use it but I noticed some static noise in the playback that I am 99% sure it is unintended…It seems to happen for presets with 8 voices…Is this my CPU struggling? Is there a way to optimize my set up? I am using latest Reaper DAW. Keep up the great work!
    Thank you!
    If it's drop outs you can reduce this by making the buffer a little bit larger.  Alternatively, reduce to 4 voices and turn on VOICE LOCK in the settings menu.
    Dan
