Home Forums Products Stompboxes H9 Max Dark Edition not working properly Reply To: H9 Max Dark Edition not working properly
#155854
bohan
    Sounds like you have a bad unit. I'm sorry about that. I would recommend the last thing before you exchange or return it.
    Please try updating the unit with Eventide Direct Updater, which is bundled with H9 Control. If you are on Mac, you can find it in H9 Control by clicking the "Window" -> "Open Eventide Direct Updater" on the menu bar. If you are on Windows, you may just search "Direct Updater" in the Start menu. To update the unit in Direct Updater, you will need to boot your H9 into UPDATE mode by pressing the HOTKNOB while powering up.
    After the update, please do a full factory reset by powering up unit with pressing and holding the right footswitch and the big black knob until you see INITIA on the display
