Reply To: Generator midi learn ?
Home Forums Products Plug-Ins Generator midi learn ? Reply To: Generator midi learn ?
#155909
DGillespie
Can you try turning OpenGL off and turning visualizations off (you'll need to close and open the UI after turning OpenGL off)?  Does this solve your CPU problem?  I have a similar machine and the default patch uses about 20% of one core.  I would expect the same for you, but sometimes the UI animations or OpenGL can cause CPU problems on some peoples computers.
Dan
