Home › Forums › Products › Vsig and Preset Development › C_CURVE help and why does it not work like I’d expect? › Reply To: C_CURVE help and why does it not work like I’d expect?
October 30, 2020 at 9:54 pm
#156193
Ok, so it seems that there is a ‘quirk’ with this module. The map arrives at the last point before the input reaches 1. The less points you have specified the worse the problem becomes. With 32 points specified the last point is arrived at with an input of .938, however if you only have 4 points specified that last point is arrived at with an input value of only .5!!
