Home Forums Products Stompboxes Assign expression pedal always to (dry/wet) ‘mix’ H9 Reply To: Assign expression pedal always to (dry/wet) ‘mix’ H9
#156235
bohan
    Stereovolt wrote:
    Sooo How do we do it? So frustrated that this cannot be done easily.
    What do you want to do? You can either set the EXP mapping to just the Mix knob, or as Nick said you can use a MIDI controller and map it to knob 9 in H9's midi settings.
