Reply To: Can you downgrade firmware on TF?
Home Forums Products Stompboxes Can you downgrade firmware on TF? Reply To: Can you downgrade firmware on TF?
#156244
bohan
I don't have any problem importing his preset. You'll need to first update your TF to the latest software using the Direct Updater, then you should be able to use H9 Control to edit/control your TF.
You just need to drag the preset file in the H9 Control window and then load it into your TimeFactor. I have not problem import that preset. And now I export this preset again for you as attached.
