Reply To: ROSE – Subtle ops questions – could someone confirm?
Home Forums Products Stompboxes ROSE – Subtle ops questions – could someone confirm? Reply To: ROSE – Subtle ops questions – could someone confirm?
#156285
Kristal_Rose
The A or B target for CC, and no expression position A/B effect when using CC expression would still be considerably easier when attempting to sub-morph presets ‘while’ using expression morphing. I’m pretty sure continuity would be destroyed interupting a morph to jump to a setting, set parameters, then return to where one was in the expression morph.
My feature wishlist, but I’m probably your only customer for that feature, and I do have the workaround of emulating the A/B morphing externally altogether. I’d actually been planning on writing that for like a decade now for other devices anyhow. It’s why I got the iPad Lemur app.
Good point on the ‘only changed values’ efficacy.
Thanks, all done here.
