Home Forums Products Stompboxes H9 low hum noise issue Reply To: H9 low hum noise issue
#156660
joecozzi
    sillybat wrote:
    Is there a workaround or any idea what to try in order to eliminate this hum noise?
    Have you tried using another set of cables? Bad cables are notorious for causing hum issues in a DJ setup.
    Have you tried using another device in the effects loop? Is the hum still there regardless? Just trying to narrow down where the hum is coming from, whether it’s your effects or it might me the mixer itself.
    Disconnect the Xone’s outputs from your main speakers and simply monitor it in your headphones. Do you still hear the hum?
