Home Forums Products Stompboxes H9 Maxout bundle, multiple issues after upgrade Reply To: H9 Maxout bundle, multiple issues after upgrade
#156764
gerax
    joecozzi wrote:
    Ok, try this. Back up any custom presets you have on the pedal to a list. Then, conduct a factory reset of the pedal by holding down the right footswitch and big black encoder simultaneously while power cycling the pedal. The words [INITIA] should pop up. Then, try the firmware update again.
    I just did, the factory reset worked but the FW update gets stuck no matter what. I have the presets backed up on the iOS app so I can try it again if you think that can yield any result. I have downloaded and installed the H9 Control MacOS app available on the Download section (it reads 3.7 on the install volume).
