Home Forums Products Stompboxes Performance/hot switch activation by midi Reply To: Performance/hot switch activation by midi
#156867
joecozzi
    MattDrago wrote:
    I saw on another thread someone saying that the midi CC message for toggling the performance switch on TimeFactor algorithms is apparently the same for On and Off as well, and that seems to be exactly what’s happening to me.
    As with any parameter or switch, you can assign which MIDI CC# will correspond to that function. Have you checked that a CC# is not assigned to both functions simultaneously?
    Best recommendation I can give you is to connect your TimeFactor to H9 Control (either directly to a computer via USB or to a tablet using the USB camera adapter). In the Pedal tab, MIDI settings, Assign MIDI CC Messages, you can see what is currently assigned and make changes. This way you can ensure no two functions are getting confused.
