Home Forums Products Stompboxes Performance/hot switch activation by midi Reply To: Performance/hot switch activation by midi
#156869
joecozzi
    This information is from a forum user named “Brock”:
    Technically, the HotSwitch started with Space, plus H9 Special algorithms. Those algorithms turn on & off like this:
    CC Number [0-99] + CC Value [64-127] = ON
    CC Number [0-99] + CC Value [00-63] = OFF
    It’s safe to say that the CC Value can be 127 for ON, and 0 for OFF. The ModFactor and PitchFactor algorithms act the same way, except it’s a more limited Performance Switch action [Brake; Slow/Fast, or Flex/Repeat].
    Where it gets dicey is in the TimeFactor-based algorithms. One CC value turns the Repeat function both ON & OFF. For argument’s sake, let’s call it a CC Value of 127 for ON.
    CC Number [0-99] + CC Value [64-127] = ON.
    CC Number [0-99] + CC Value [64-127] = OFF
    One way to cover all of the bases is to have two separate MIDI switches for ON & OFF. One switch sends CC Value = 127, and the other sends CC Value = 0.
    A single MIDI switch that alternates with each press between 127 & 0 values can cover any HotSwitch or Performance option, except for the TimeFactor algos.
