Home Forums Products Stompboxes Power Supply for Timefactor Reply To: Power Supply for Timefactor
#156962
bohan
    npx wrote:
    Hello from Germany,
    9V and 1500 mA should be okay as I have seen in some comments.
    But a question regarding the polarity of the connector: in the middle + and on the outside ring –
    Is this correct?
    Yes correct. The jack should be 5.5/2.5 mm center positive.
    However, 9V/500ma should be good enough. You don't need 1500mA.
