Reply To: H9 Killdry
Home Forums Products Stompboxes H9 Killdry Reply To: H9 Killdry
#157027
gas hed
nickrose wrote:
gas hed wrote:
Can someone help me understand the advantage of Killdry?  I have one H9 that I use in my amplifier’s tube drive, buffered FX loop.  If I use Killdry what (if anything) will it do with my tone?
The purpose of KillDry is to (wait for it) kill the dry signal, so the MIX control just adjusts the wet level. It would normally be used with a parallel effects loop or in a mixer effects send/return setup to avoid having adding the dry signal from the pedal to the effects loop/mixer dry signal.
Beyond this, it should not affect the tone.
Thanks for the feedback.  I suppose this is more of a curiosity question and that nagging thought of “maybe it could sound even better!”.  I’m guessing my Suhr PT15 amp has a parallel effects loop.  But does it matter if I send dry signal into my loop along with the wet signal?  Like does it really have any impact on tone?  I’m guessing not, but I guess I should experiment to find out for sure.
