Home Forums Products Stompboxes H9 Max Dark Edition not working properly Reply To: H9 Max Dark Edition not working properly
#157178
bohan
    It's also worth trying updating the unit again with Direct Updater, which is bundled with H9 Control. You can find it by just search "Direct Updater" in the start menu on your PC. If these all don't work, you should consider returning or exchanging it.
