Home Forums Products Plug-Ins Blackhole and Elevate plugins not showing in Logic, but they do in FCP (MacMini M1) Reply To: Blackhole and Elevate plugins not showing in Logic, but they do in FCP (MacMini M1)
#157246
tlongabaugh
    Hey, can you try the following steps and let us know if they resolve your issue?
    1. Close Logic Pro X
    2. Make sure Finder is the active application
    3. While holding the Option key, click on the Go menu at the top of your screen and select Library
    4. Delete the following files from your User Library, if they are present:
      1. ~/Library/Caches/com.apple.audiounits.cache
      2. The contents of ~/Library/Caches/AudioUnitCache/
      3. ~/Library/Preferences/com.apple.audio.InfoHelper.plist
      4. ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
    5. Then, open a Terminal window (Applications -> Utilities -> Terminal), and enter the following commands (type each command and press "Enter" afterwards)
      1. killall -9 cfprefsd
      2. killall -9 AudioComponentRegistrar
    6. Restart Logic Pro X
