Home › Forums › Products › Stompboxes › MIDI CC mapping doesn’t “stick” › Reply To: MIDI CC mapping doesn’t “stick”
I've used the H9 Control app (in Windows) to map MIDI CC 12 to the HotKnob value. It works fine with the CC messages coming from a Boss MS-3…but only when the H9 Control app is running. When the app's not there and connected via USB, it quits listening to the CC 12 messages.
How do you get the control mapping to "stick" when the app's not there? How do you actually SAVE it to the pedal?
(This sounds like a really basic question that must have been answered many times by now.)
This sounds not right. Is MS-3 connected to H9 via a 5-pin MIDI cable? H9 will ignore the 5-pin connection if its USB port is connected.
You should only connect the 5-pin MIDI. The mapping can be done on the unit too in the settings menu (long press the HOTKNOB + right FSW)
