Home Forums Products Stompboxes H9 tuner via G3 atom Reply To: H9 tuner via G3 atom
#157330
andysalt
    Thanks, I’ve managed to get it to work via cc as well now, rather than PC.
    The thing I don’t seem to be able to do, I think because it’s a ‘toggle’ option is ensure I’m able to only select the tuner on the hidden preset. Depending on which state the H9 is in when I then select the hidden preset means that it will always only ‘toggle’ (Tuner on/off). The limitation here being what state the H9 is in when I drop in to preset 1, then 9 in order to access the tuner.
    It would be ace if it was possible to assign the tuner to a preset – but I think this has been asked before and advised it isn’t possible? .
    thanks,
