Home › Forums › Products › Stompboxes › Why Do My Presets Go Blank?!?!?! › Reply To: Why Do My Presets Go Blank?!?!?!
March 4, 2021 at 2:18 pm
#157333
bohan wrote:
apalazzolo wrote:
This works and it’s even better than you said. I can change the knob setting and rename a preset WITHOUT SELECTING SAVE AGAIN and the settings and new name are both remembered.
Thank you so much!
You’re welcome. You should make sure you click the “Save” button. For example, if you make changes and then click the “Algorithms” tab, you may lose your changes.
I’ll watch out for that but I did specifically test for that concern before posting my comment and the changes did “stick”.
Once again, thanks for addressing these problems.
