Reply To: Pedalboard power combining boxes
Home Forums Products Stompboxes Pedalboard power combining boxes Reply To: Pedalboard power combining boxes
#157469
joecozzi
All Eventide pedals can most certainly be used with any pedalboard power supply that delivers adequate power. It must have a 9v outlet that delivers 500mA of current for your H9. The only accessory you may need is a polarity reversal cable. H9 uses a center positive connector where most pedals like your Boss use center negative. This will work:
http://www.voodoolab.com/shop/index.php?cPath=22_24_30&osCsid=p1hmh9e590bfue563pfti33bi5
Eventide makes its own pedal board power supply solution in two formats that would allow you to connect all your pedals – Boss, Eventide, or other – very easily with all the necessary cables.
PowerMax: https://www.eventideaudio.com/products/accessories/power-supply/powermax
PowerMini: https://www.eventideaudio.com/products/accessories/power-solution/powermini
