Home Forums Products Plug-Ins Blackhole VST – Mouse Scroll not modifying correct parameters on knob hover Reply To: Blackhole VST – Mouse Scroll not modifying correct parameters on knob hover
#157731
    Thanks for the info. We weren't able to reproduce this issue using Bitwig 3.2 on Windows 10.
    Could you check if this also happens for you when using the VST2 version of the plug-in?
    If you have another DAW you could test this with, that would be helpful too.
