Home › Forums › Products › Stompboxes › Micro Pitch Device Mgr. Issue › Reply To: Micro Pitch Device Mgr. Issue
May 30, 2021 at 9:21 pm
#157978
If you have EDM open, check to make sure it’s not waiting for you to SAVE or CANCEL before you try to do anything else. You’ll see the prompt up top in yellow. If you try to change presets without first answering that query, you won’t get a response from the pedal. Just hit CANCEL and everything will function normally again. Let me know if that helps.
