Home › Forums › Products › Stompboxes › Super strange routing issue! › Reply To: Super strange routing issue!
June 10, 2021 at 6:45 pm
#158080
joecozzi wrote:
Matching impedances between I/O and in-chain effects is very important. Maybe the amp’s effects loop is playing a larger role than you think.
Could be something the amp is sending a lot of gain then ive got a master volume control. Although that other time i tried no fx loop.
Are you saying it might function better with a buffer? I used to use an active volume pedal (ernie ball MVP) that i can still try and dont care less about buffered bypass in fx loop. Coincidentally it splits into a good sounding tuner out too, so maybe even as my active splitter (would only control one channel) if it doesnt.
