Home Forums Products Stompboxes Using H9 with Digitech FS3X. What’s the trick? Reply To: Using H9 with Digitech FS3X. What’s the trick?
#158421
Boynigel
    joecozzi wrote:
    I just tried that preset on my H9 and I cannot find any issue with it. On my aux switch TIP is assigned to the PERFORMANCE SWITCH. Please send me a screenshot of your Aux Switch Mappings. I still think the issue is there.
    Okay, so I managed to get it working how I need it to be last night just before going to bed.  This leaves me with one final question regarding how to set the high/low parameters in an algorithm such as Space.
     You mentioned I won’t see blue ranges on the knobs because it isn’t an expression pedal mapping in said algorithm.  That’s fine, but how do I set them?  They’re obviously still set-able (minus the blue rings) as certain values are responding in the factory presets to my FS3 Mode button.
     Do I do it the same way as I would with an expression pedal setting, and I just won’t see the blue range?  Unfortunately I’m at work all day so I haven’t had a chance to try it hands-on, and by the time I get home you’ll be gone so I figured I’d ask now in hopes of avoiding any kind of road block.  thanks for your help.
