Home › Forums › Products › Stompboxes › H9 noises › Reply To: H9 noises
August 30, 2021 at 5:31 pm
#158482
I would say not the H9, for one, because I think you can see the signal light flashing on/off with the noise. That indicates to me something is getting in the signal path somewhere before the H9. Is this H9 wired PRE/POST, or stereo? What happens if you use true bypass?
I would go through the connections first and eliminate any obvious sources of ground loops (non-isolated power supplies, grounds, etc.) or noise and start process of elimination between the H9 and front of the amp.
Hard to say but sounds like a power supply, interference or grounding issue to me.
