Home › Forums › Products › Stompboxes › H9 noises › Reply To: H9 noises
August 30, 2021 at 9:15 pm
#158486
The noise is still there even without DSP Bypass? RELAY (true) bypass mode should isolate noise to some degree. Using the same cables straight into the amp doesn’t reproduce the problem? Crackling and popping doesn’t sound right. Also I’ve had loud noise issues with PRE/POST routing before… In my case probably because audio grounds weren’t isolated (ground loops)…
