Home › Forums › Products › Stompboxes › Eventides not Returning MIDI to Signal Path › Reply To: Eventides not Returning MIDI to Signal Path
#158680
joecozzi
    brianyaw wrote:
    The problem is that when I change a patch on my switcher, I can see the change take effect in each of the factor pedals. BUT, the sound of the guitar is unaffected. No delay is applied, no reverb.
    Are you sure the pedals are being activated? It is possible to load presets in a bypassed state either because the presets were saved that way or because you’re sending the pedals a bypass command along with the preset change.
    Also, you’ve explained how your MIDI is connected but what about your audio? Are you daisy chaining the pedals together?
