Home Forums Products Stompboxes Eventides not Returning MIDI to Signal Path Reply To: Eventides not Returning MIDI to Signal Path
#158729
brianyaw
    If I’m restating prior territory, it’s because I can’t find it in the string….I went directly into and out of the TF without the switcher and it worked perfectly. Going directly in and directly out, but, using MIDI to change the TF delay times didn’t affect my tone. Therefore, given where we’ve been, in RCV CTL I set up for destination BYP – C0 and ACT – C1. If I then send C1 – 127 it should make the TF active and, conversely, C0 – 127 would make the TF inactive, correct?
