Home › Forums › Products › Stompboxes › Eventides not Returning MIDI to Signal Path › Reply To: Eventides not Returning MIDI to Signal Path
#158733
brianyaw
    YES!! YES!! YES!! I think there is a fault in my TF pedal. Why? I got so frustrated with it that I tried my Space and it worked – twice. Then, I tried my Modfactor and it worked! So, I did a factory reset on Timefactor and tried it clean with a fresh setting in a bank…and…it didn’t work. But, with everything connected and manually changing the effect to a reverse and then back to Vintage with A & B programmed – it worked. And, that was something I was seeing when it was in series and I wasn’t using MIDI on my board. I would always have to shift it to a different effect and then go back to the one I wanted. Given this, would you also conclude that the pedal needs to be looked at?
    Thanks again,
    Brian
