Home › Forums › Products › Stompboxes › Eventides not Returning MIDI to Signal Path › Reply To: Eventides not Returning MIDI to Signal Path
September 27, 2021 at 9:06 pm
#158734
I think it most likely something at your end, especially if you have a complex MIDI setup, with little personal MIDI experience.
But, if you are convinced that the unit is at fault, and especially if it is still under warranty (no charge), consider sending it in. support@eventide.com.
