Home › Forums › Products › Stompboxes › H9 modification for MIDI power › Reply To: H9 modification for MIDI power
#162801
    The main board is the bottom board. The only modification required is one wire at the MIDI connector.
    It’s an easy mod – you need to be “skilled” with a screwdriver to take the unit apart, then able to make two solder joints.
    The skill warning is to say you need some idea of what you are doing. Almost any wire will work – the 22 awg specification is for our manufacturing people.
