Home Forums Products Stompboxes pitchflex h9 control message Reply To: pitchflex h9 control message
#162948
bohan
    Hi, PitchFlex doesn’t support the ribbon aka HotKonb because the EXP is mapped to the heel and toe position parameters.
    If you’d like to use the EXP to morph between +-50 cents, you should use the MicroPitch algorithm and then map the Pitch parameter to the Ribbon/HotKnob/EXP.
