Home Forums Products Stompboxes MixingLink: Two Mono inputs at Instrument IN? Reply To: MixingLink: Two Mono inputs at Instrument IN?
#163113
    Using the Y-Splitter is not ideal for this configuration. Why not plug the guitar directly into one of the channels mixer instead of plugging it into the MixingLink?
    Alternatively, you could try:
    Mixer FX SEND -> ML MIC/LINE in
    Guitar -> ML INST IN
    ML DI/LINE OUT -> Mixer FX RETURN
    The input gain will apply to both the MIC/LINE in and INST IN simultaneously so you’ll have to set the level of your sources accordingly, but this would be a better configuration than using a splitter to sum 2 sources to the INST IN.
