Home › Forums › Products › Vsig and Preset Development › H9000+Vsig3 bugs › Reply To: H9000+Vsig3 bugs
I’ve double checked this now. It may be my looper algo but I’m not sure how. I can send it to you to test but since there is also a long standing text trigger bug that remains unfixed you won’t be able to use it via emote. Front panel usage only. I’ve tested midi sync with both Logic and an Arturia key step sending clock directly to the H9k.
What happens is eventually sync kind of ‘pops’ out of place and notes are delayed. A reset is the only solution at that point. Sometimes it happens within seconds, sometimes not for minutes. It’s maddeningly inconsistent and I’ve spent many hours trying to track it down. It seems like, but it’s hard to tell, that the longer the algorithm has been loaded the quicker it goes out of sync.
Here is the looper Sig file inline:
HEADM|adc|ninputs=2|noutputs=8|name=0|tag=0|nkids=1|out1=Sum:1-out|out2=Sum:2-out|out3=Sum:3-out|out4=Sum:4-out|out5=Sum:5-out|out6=Sum:6-out|out7=Sum:7-out|out8=Sum:8-out|kids1=uo_switch:1-obj
MIDICLOCK|_midiclock>>|time_in=500|freq_in=1|start_in=0|stop_in=0|remote_mode=0|clock_in=1
C_ADDER|>FromStop:1|ninputs=2|in1=_midiclock>>-stop_out|in2=0
C_ADDER|>FromBeat:1|ninputs=2|in1=_midiclock>>-beat_out|in2=0
KNOB|Beats:1|statement=ReTrigger Beats:%1.f|name=0|min=2|max=128|res=1|default=8
C_SUBTRACT|c_subtract:1|in1=Beats:1-out|in2=2
C_COMPARATOR|c_comparator:1|in1=BeatCounter:1-out|in2=c_subtract:1-out
C_ADDER|Clock_Stop_In:1|ninputs=2|in1=>FromStop:1-out|in2=c_comparator:1-out
C_ADDER|Add_Reset_Signal_to_clock_signal_for_reset|ninputs=2|in1=>FromBeat:1-out|in2=>FromStop:1-out
C_RESET|Ignore_first_otherwise_starts_recording_on_Load|time=100
C_AND|Gate_for_ignore_first>>|in1=Add_Reset_Signal_to_clock_signal_for_reset-out|in2=Ignore_first_otherwise_starts_recording_on_Load-nout
C_COUNT2|BeatCounter:1|clock=Gate_for_ignore_first>>-out|incr=1|maxcount=32000|reset=Clock_Stop_In:1-out
C_CMP2|Send_signal_on_first_beat|in1=BeatCounter:1-out|in2=1
TEXTTRIGGER|Record_Trigger:1|nstrings=4|textnum=Process_status_signal_for_text_trigger-out|text1=Stop|text2=Set Loop|text3=Play|text4=Overdub
C_ADDER|Record_button_mixed_here_to_increase_count|ninputs=3|in1=ArmSwitch-out|in2=Clear:1-out|in3=Record_Trigger:1-out
C_COUNT2|Counter_for_inital_auto_record_mechanism|clock=Record_button_mixed_here_to_increase_count-out|incr=1|maxcount=4|reset=Clear:1-out
C_CMP2|Only_count_first_2_beat_1_signls|in1=Counter_for_inital_auto_record_mechanism-out|in2=2
C_AND|Once_first_2_beat_1_signals_have_played_allow_loop_retrigger|in1=Send_signal_on_first_beat-eq|in2=Only_count_first_2_beat_1_signls-ge
TEXTTRIGGER|AutoloopArm:1|nstrings=2|textnum=Disable_arm_on_first_loop_retrigger-out|text1=Arm Autoloop|text2=Armed
C_ADDER|Clear_button_Also_Disables_Autoarm|ninputs=2|in1=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger-out|in2=Clear:1-out
C_FLOP|Disable_arm_on_first_loop_retrigger|reset=Clear_button_Also_Disables_Autoarm-out|set=0|toggle=AutoloopArm:1-out
C_MULTIPLY|ArmSwitch|in1=Send_signal_on_first_beat-eq|in2=Disable_arm_on_first_loop_retrigger-out
C_AND|Gate_open_for_1st_2_beat1_triggers|in1=ArmSwitch-out|in2=Only_count_first_2_beat_1_signls-le
C_ADDER|Mix_Beat_Triggers_with_record_button|ninputs=2|in1=Gate_open_for_1st_2_beat1_triggers-out|in2=Record_Trigger:1-out
C_ADDER|RecTrigAdder:1|ninputs=2|in1=Record_Trigger:1-out|in2=AuTrgMath5:1-out
C_ADDER|Mix_Free&Sync_Rec_Triggers:1|ninputs=2|in1=Mix_Beat_Triggers_with_record_button-out|in2=RecTrigAdder:1-out
C_TO_A|RecTrigConvert:1|in=Mix_Free&Sync_Rec_Triggers:1-out
C_TO_A|c_to_a:2|in=Clear:1-out
TEXTKNOB|OneShotPlay:1|statement=One Shot: %s|name=Direction|nchoices=2|default=0|choices1=OFF|choices2=ON
C_OSWITCH|OneShotSwitch|noutputs=2|select=OneShotPlay:1-out|in=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger-out|defaultout1=0|defaultout2=0
TEXTKNOB|_ModeSwitch>|statement=Looper Mode:%s|name=0|nchoices=2|default=0|choices1=Sync|choices2=Free
C_ADDER|>FromModeSw:1|ninputs=2|in1=_ModeSwitch>-out|in2=0
C_NOT|c_not:1|in=>FromModeSw:1-out
C_AND|Dont_allow_loopRetrigger_if_in_FreeMode:1|in1=c_not:1-out|in2=OneShotSwitch-out1
C_TO_A|LoopConvert:1|in=Dont_allow_loopRetrigger_if_in_FreeMode:1-out
TEXTKNOB|Direction:1|statement=Direction: %s|name=Direction|nchoices=2|default=0|choices1=Forward|choices2=Reverse
C_TABLE|DirectionMath1:1|nentries=2|select=Direction:1-out|in1=1|in2=-1
KNOB|Speed:1|statement=Pitch:%2.0f|name=Speed|min=-60|max=0|res=1|default=0
C_ADDER|SpeedMath1:1|ninputs=2|in1=Speed:1-out|in2=60
C_TABLE|SpeedMath2:1|nentries=61|select=SpeedMath1:1-out|in1=3.125|in2=3.311|in3=3.508|in4=3.716|in5=3.938|in6=4.172|in7=4.42|in8=4.683|in9=4.961|in10=5.256|in11=5.569|in12=5.9|in13=6.25|in14=6.622|in15=7.016|in16=7.433|in17=7.875|in18=8.344|in19=8.84|in20=9.365|in21=9.92|in22=10.51|in23=11.14|in24=11.8|in25=12.5|in26=13.24|in27=14.03|in28=14.87|in29=15.75|in30=16.69|in31=17.68|in32=18.73|in33=19.84|in34=21.02|in35=22.27|in36=23.6|in37=25|in38=26.49|in39=28.06|in40=29.73|in41=31.5|in42=33.37|in43=35.36|in44=37.46|in45=39.69|in46=42.05|in47=44.55|in48=47.2|in49=50|in50=52.98|in51=56.13|in52=59.47|in53=63|in54=66.75|in55=70.71|in56=74.92|in57=79.38|in58=84.1|in59=89.1|in60=94.4|in61=100
C_MULTIPLY|SpeednDirectn:1|in1=SpeedMath2:1-out|in2=DirectionMath1:1-out
TRIGGER|Undo:1|name=Undo|statement=Undo|tag=Undo
C_TO_A|c_to_a:4|in=Undo:1-out
KNOB|TrimEnd:1|statement=Trim End:%3.2f%%|name=0|min=-100|max=0|res=.01|default=0
C_DIVIDE|c_divide:9|in1=TrimEnd:1-out|in2=100
C_MULTIPLY|c_multiply:1|in1=dlysmp2n:1-reclength|in2=c_divide:9-out
TEXTKNOB|InSelect:1|statement=Input Select:%s|name=0|nchoices=4|default=0|choices1=Input|choices2=B Loop Resamp|choices3=C Loop Resamp|choices4=D Loop Resamp
ISWITCH|In_Switch_R:1|numins=4|select=InSelect:1-out|in1=adc-in2|in2=Filter_R:2-out|in3=Filter_R:3-out|in4=Filter_R:4-out
ISWITCH|In_Switch_L:1|numins=4|select=InSelect:1-out|in1=adc-in1|in2=Filter_L:2-out|in3=Filter_L:3-out|in4=Filter_L:4-out
TAPKNOB|SpliceFade:1|statement=Splice Fade:%3.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
TAPKNOB|DubFade:1|statement=Dub Fade:%4.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
C_NOT|InvertShotSignal|in=OneShotPlay:1-out
C_1SHOT|Send_Play_Signal_When_OneShot_turns_Off|in=InvertShotSignal-out
C_ADDER|Mix_in_Shot_Off_Play_Signal|ninputs=2|in1=OneShotSwitch-out2|in2=Send_Play_Signal_When_OneShot_turns_Off-out
C_AND|Dont_allow_PlayTrigger_if_in_FreeMode:1|in1=c_not:1-out|in2=Mix_in_Shot_Off_Play_Signal-out
C_1SHOT|c_1shot:1|in=>FromModeSw:1-out
C_AND|Send_signal_if_OneShotMode_turned_On|in1=c_1shot:1-out|in2=OneShotPlay:1-out
C_ADDER|Mix_Play_Signal_at_Switch_to_Free_Mode|ninputs=2|in1=Send_signal_if_OneShotMode_turned_On-out|in2=Dont_allow_PlayTrigger_if_in_FreeMode:1-out
C_TO_A|PlayConvert:1|in=Mix_Play_Signal_at_Switch_to_Free_Mode-out
KNOB|TrimStart:1|statement=Trim Start:%3.2f%%|name=0|min=0|max=100|res=.01|default=0
C_DIVIDE|c_divide:10|in1=TrimStart:1-out|in2=100
C_MULTIPLY|c_multiply:2|in1=dlysmp2n:1-reclength|in2=c_divide:10-out
KNOB|Decay:1|statement=Decay:%3.0f%%|name=Decay|min=0|max=100|res=1|default=100
C_MULTIPLY|DecayInvert1:1|in1=Decay:1-out|in2=-1
C_ADDER|c_adder:3|ninputs=2|in1=DecayInvert1:1-out|in2=100
C_SWITCH|OneShot_not_allowed_in_free_mode|ninputs=2|select=>FromModeSw:1-out|in1=InvertShotSignal-out|in2=1
DLYSMP2N|dlysmp2n:1|numtracks=2|maxdelay=500|maxsplice=100|rectrigger=RecTrigConvert:1-out|stoptrigger=c_to_a:2-out|playtrigger=PlayConvert:1-out|looptrigger=LoopConvert:1-out|undo_redo=c_to_a:4-out|begin_mod=adc-null|end_mod=adc-null|maxlength=124.9|beginpt=c_multiply:2-out|endpt=c_multiply:1-out|dubfade=DubFade:1-out|splicelength=SpliceFade:1-out|playspeed=SpeednDirectn:1-out|decay=c_adder:3-out|loopmode=OneShot_not_allowed_in_free_mode-out|playmode=0|timeoutmode=1|dubmode=0|in1=In_Switch_L:1-out|in2=In_Switch_R:1-out
C_DIVIDE|Process_status_signal_for_text_trigger|in1=dlysmp2n:1-statusout|in2=4
C_DIVIDE|c_divide:1|in1=dlysmp2n:1-position|in2=dlysmp2n:1-reclength
C_MERGE|ClearButton_Resets_Display:1|ninputs=2|in1=c_divide:1-out|in2=Clear:1-out
HMONITOR|LoopPosition:1|in=ClearButton_Resets_Display:1-out|minimum=0.0|maximum=1.0|name=Loop Position|tag=Loop Position
TEXTKNOB|OutSelect:1|statement=Output Assign:%s|name=0|nchoices=4|default=0|choices1=1 + 2|choices2=3 + 4|choices3=5 + 6|choices4=7 + 8
KNOB|Pan1:1|statement=Pan:%1.0f|name=0|min=-50|max=50|res=1|default=0
TAPKNOB|Volume1:1|statement=Volume:%1.1f db|name=0|min=-100|max=0|steps=200|default=0|taper=3|alpha=1
C_DIVIDE|c_divide:2|in1=Pan1:1-out|in2=25
C_ADDER|c_adder:4|ninputs=2|in1=c_divide:2-out|in2=1
C_ADDER|c_adder:5|ninputs=2|in1=c_divide:2-out|in2=-1
C_ABS|PanLaw1:1|input=Pan1:1-out
C_DIVIDE|PanLaw2:1|in1=PanLaw1:1-output|in2=-16
C_ADDER|MixPanning:1|ninputs=2|in1=Volume1:1-out|in2=PanLaw2:1-out
TEXTKNOB|MuteSwitch:1|statement=A:%s|name=0|nchoices=2|default=1|choices1=Mute|choices2=Active
C_SWITCH|MuteSel:1|ninputs=2|select=MuteSwitch:1-out|in1=-100|in2=MixPanning:1-out
STEREOMIXER|stereomixer:1|ninputs=2|time_constant=20|clipvalue=10000|processoff=0|in1=dlysmp2n:1-out1|in2=dlysmp2n:1-out2|gain1=MuteSel:1-out|gain2=MuteSel:1-out|pan1=c_adder:5-out|pan2=c_adder:4-out
TEXTKNOB|FilterType:1|statement=Filter Type:%s|name=0|nchoices=3|default=0|choices1=Bypass|choices2=Lowpass|choices3=Highpass
C_TABLE|c_table:1|nentries=3|select=FilterType:1-out|in1=10|in2=8|in3=1
TAPKNOB|Q:1|statement=Q:%2.2f|name=0|min=.5|max=20|steps=300|default=.8|taper=2|alpha=1
TAPKNOB|Frequency:1|statement=Cutoff:%4.1fHz|name=0|min=20|max=20000|steps=1000|default=2700|taper=2|alpha=1
EQS|Filter_R:1|neqs=1|clipvalue=10000|in=stereomixer:1-right|processoff=0|freq1=Frequency:1-out|qfactor1=Q:1-out|boost1=0|type1=c_table:1-out
EQS|Filter_L:1|neqs=1|clipvalue=10000|in=stereomixer:1-left|processoff=0|freq1=Frequency:1-out|qfactor1=Q:1-out|boost1=0|type1=c_table:1-out
OSWITCH|LSwitch:1|numouts=4|in=Filter_L:1-out|select=OutSelect:1-out
OSWITCH|RSwitch:1|numouts=4|in=Filter_R:1-out|select=OutSelect:1-out
MENUPAGE|Sync_Pg1:1|name=A_LOOP_A|tag=0|nsubuos=8|obj1=Record_Trigger:1-obj|obj2=Clear:1-obj|obj3=Undo:1-obj|obj4=Decay:1-obj|obj5=AutoloopArm:1-obj|obj6=Beats:1-obj|obj7=OneShotPlay:1-obj|obj8=LoopPosition:1-obj
MENUPAGE|Playback:1|name=A_Playback_A|tag=0|nsubuos=8|obj1=Direction:1-obj|obj2=Speed:1-obj|obj3=TrimStart:1-obj|obj4=TrimEnd:1-obj|obj5=FilterType:1-obj|obj6=Frequency:1-obj|obj7=Q:1-obj|obj8=LoopPosition:1-obj
MENUPAGE|Mix-Details:1|name=A_Mix/Details_A|tag=0|nsubuos=7|obj1=Volume1:1-obj|obj2=Pan1:1-obj|obj3=SpliceFade:1-obj|obj4=DubFade:1-obj|obj5=InSelect:1-obj|obj6=OutSelect:1-obj|obj7=LoopPosition:1-obj
TAPKNOB|Global_Threshold:1|statement=Auto Threshld:%0.3f%|name=0|min=.00002|max=.2|steps=300|default=.002|taper=1|alpha=1
MENUPAGE|Global|name=Global Settings|tag=0|nsubuos=2|obj1=_ModeSwitch>-obj|obj2=Global_Threshold:1-obj
TEXTTRIGGER|Auto_Thresh_Arm_freemode:1|nstrings=2|textnum=Hitting_record_disables_Auto_threshold_record:1-out|text1=Arm Auto Thresh|text2=Armed
MENUPAGE|Free_Pg1:1|name=A_LOOP_A|tag=0|nsubuos=6|obj1=Record_Trigger:1-obj|obj2=Clear:1-obj|obj3=Undo:1-obj|obj4=Decay:1-obj|obj5=Auto_Thresh_Arm_freemode:1-obj|obj6=LoopPosition:1-obj
C_NOT|input_from_StatusOut_Freemode:1|in=dlysmp2n:1-statusout
ADD|In_from_ADC:1|clipvalue=10000|in1=adc-in1|in2=adc-in2
ONESHOT|AuTrgMath1:1|in=In_from_ADC:1-out|time=10|threshold=Global_Threshold:1-out
A_TO_C|_AudioTrigOut>|in=AuTrgMath1:1-out
C_ADDER|>FromAudioTrg:1|ninputs=2|in1=_AudioTrigOut>-out|in2=Record_Trigger:1-out
C_FLOP|Hitting_record_disables_Auto_threshold_record:1|reset=RecTrigAdder:1-out|set=0|toggle=Auto_Thresh_Arm_freemode:1-out
C_AND|AudioTrgIn:1|in1=Hitting_record_disables_Auto_threshold_record:1-out|in2=input_from_StatusOut_Freemode:1-out
C_COUNT2|AuTrgMath4:1|clock=>FromAudioTrg:1-out|incr=1|maxcount=AudioTrgIn:1-out|reset=Clear:1-out
C_1SHOT|AuTrgMath5:1|in=AuTrgMath4:1-out
C_ADDER|>FromStop:2|ninputs=2|in1=_midiclock>>-stop_out|in2=0
C_ADDER|>FromBeat:2|ninputs=2|in1=_midiclock>>-beat_out|in2=0
KNOB|Beats:2|statement=ReTrigger Beats:%1.f|name=0|min=2|max=128|res=1|default=8
C_SUBTRACT|c_subtract:2|in1=Beats:2-out|in2=2
C_COMPARATOR|c_comparator:2|in1=BeatCounter:2-out|in2=c_subtract:2-out
C_ADDER|Clock_Stop_In:2|ninputs=2|in1=>FromStop:2-out|in2=c_comparator:2-out
C_ADDER|Add_Reset_Signal_to_clock_signal_for_reset:1|ninputs=2|in1=>FromBeat:2-out|in2=>FromStop:2-out
C_RESET|Ignore_first_otherwise_starts_recording_on_Load:1|time=100
C_AND|Gate_for_ignore_first>>:1|in1=Add_Reset_Signal_to_clock_signal_for_reset:1-out|in2=Ignore_first_otherwise_starts_recording_on_Load:1-nout
C_COUNT2|BeatCounter:2|clock=Gate_for_ignore_first>>:1-out|incr=1|maxcount=32000|reset=Clock_Stop_In:2-out
C_CMP2|Send_signal_on_first_beat:1|in1=BeatCounter:2-out|in2=1
TEXTTRIGGER|Record_Trigger:2|nstrings=4|textnum=Process_status_signal_for_text_trigger:1-out|text1=Stop|text2=Set Loop|text3=Play|text4=Overdub
TRIGGER|Clear:2|name=CLEAR|statement=Clear|tag=Clear
C_ADDER|Record_button_mixed_here_to_increase_count:1|ninputs=3|in1=ArmSwitch:1-out|in2=Clear:2-out|in3=Record_Trigger:2-out
C_COUNT2|Counter_for_inital_auto_record_mechanism:1|clock=Record_button_mixed_here_to_increase_count:1-out|incr=1|maxcount=4|reset=Clear:2-out
C_CMP2|Only_count_first_2_beat_1_signls:1|in1=Counter_for_inital_auto_record_mechanism:1-out|in2=2
C_AND|Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:1|in1=Send_signal_on_first_beat:1-eq|in2=Only_count_first_2_beat_1_signls:1-ge
TEXTTRIGGER|AutoloopArm:2|nstrings=2|textnum=Disable_arm_on_first_loop_retrigger:1-out|text1=Arm Autoloop|text2=Armed
C_ADDER|Clear_button_Also_Disables_Autoarm:1|ninputs=2|in1=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:1-out|in2=Clear:2-out
C_FLOP|Disable_arm_on_first_loop_retrigger:1|reset=Clear_button_Also_Disables_Autoarm:1-out|set=0|toggle=AutoloopArm:2-out
C_MULTIPLY|ArmSwitch:1|in1=Send_signal_on_first_beat:1-eq|in2=Disable_arm_on_first_loop_retrigger:1-out
C_AND|Gate_open_for_1st_2_beat1_triggers:1|in1=ArmSwitch:1-out|in2=Only_count_first_2_beat_1_signls:1-le
C_ADDER|Mix_Beat_Triggers_with_record_button:1|ninputs=2|in1=Gate_open_for_1st_2_beat1_triggers:1-out|in2=Record_Trigger:2-out
C_ADDER|RecTrigAdder:2|ninputs=2|in1=Record_Trigger:2-out|in2=AuTrgMath5:2-out
C_ADDER|Mix_Free&Sync_Rec_Triggers:2|ninputs=2|in1=Mix_Beat_Triggers_with_record_button:1-out|in2=RecTrigAdder:2-out
C_TO_A|RecTrigConvert:2|in=Mix_Free&Sync_Rec_Triggers:2-out
C_TO_A|c_to_a:3|in=Clear:2-out
TEXTKNOB|OneShotPlay:2|statement=One Shot: %s|name=Direction|nchoices=2|default=0|choices1=OFF|choices2=ON
C_OSWITCH|OneShotSwitch:1|noutputs=2|select=OneShotPlay:2-out|in=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:1-out|defaultout1=0|defaultout2=0
C_ADDER|>FromModeSw:2|ninputs=2|in1=_ModeSwitch>-out|in2=0
C_NOT|c_not:2|in=>FromModeSw:2-out
C_AND|Dont_allow_loopRetrigger_if_in_FreeMode:2|in1=c_not:2-out|in2=OneShotSwitch:1-out1
C_TO_A|LoopConvert:2|in=Dont_allow_loopRetrigger_if_in_FreeMode:2-out
TEXTKNOB|Direction:2|statement=Direction: %s|name=Direction|nchoices=2|default=0|choices1=Forward|choices2=Reverse
C_TABLE|DirectionMath1:2|nentries=2|select=Direction:2-out|in1=1|in2=-1
KNOB|Speed:2|statement=Pitch:%2.0f|name=Speed|min=-60|max=0|res=1|default=0
C_ADDER|SpeedMath1:2|ninputs=2|in1=Speed:2-out|in2=60
C_TABLE|SpeedMath2:2|nentries=61|select=SpeedMath1:2-out|in1=3.125|in2=3.311|in3=3.508|in4=3.716|in5=3.938|in6=4.172|in7=4.42|in8=4.683|in9=4.961|in10=5.256|in11=5.569|in12=5.9|in13=6.25|in14=6.622|in15=7.016|in16=7.433|in17=7.875|in18=8.344|in19=8.84|in20=9.365|in21=9.92|in22=10.51|in23=11.14|in24=11.8|in25=12.5|in26=13.24|in27=14.03|in28=14.87|in29=15.75|in30=16.69|in31=17.68|in32=18.73|in33=19.84|in34=21.02|in35=22.27|in36=23.6|in37=25|in38=26.49|in39=28.06|in40=29.73|in41=31.5|in42=33.37|in43=35.36|in44=37.46|in45=39.69|in46=42.05|in47=44.55|in48=47.2|in49=50|in50=52.98|in51=56.13|in52=59.47|in53=63|in54=66.75|in55=70.71|in56=74.92|in57=79.38|in58=84.1|in59=89.1|in60=94.4|in61=100
C_MULTIPLY|SpeednDirectn:2|in1=SpeedMath2:2-out|in2=DirectionMath1:2-out
TRIGGER|Undo:2|name=Undo|statement=Undo|tag=Undo
C_TO_A|c_to_a:5|in=Undo:2-out
KNOB|TrimEnd:2|statement=Trim End:%3.2f%%|name=0|min=-100|max=0|res=.01|default=0
C_DIVIDE|c_divide:11|in1=TrimEnd:2-out|in2=100
C_MULTIPLY|c_multiply:3|in1=dlysmp2n:2-reclength|in2=c_divide:11-out
TEXTKNOB|InSelect:2|statement=Input Select:%s|name=0|nchoices=4|default=0|choices1=Input|choices2=A Loop Resamp|choices3=C Loop Resamp|choices4=D Loop Resamp
ISWITCH|In_Switch_R:2|numins=4|select=InSelect:2-out|in1=adc-in2|in2=Filter_R:1-out|in3=Filter_R:3-out|in4=Filter_R:4-out
ISWITCH|In_Switch_L:2|numins=4|select=InSelect:2-out|in1=adc-in1|in2=Filter_L:1-out|in3=Filter_L:3-out|in4=Filter_L:4-out
TAPKNOB|SpliceFade:2|statement=Splice Fade:%3.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
TAPKNOB|DubFade:2|statement=Dub Fade:%4.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
C_NOT|InvertShotSignal:1|in=OneShotPlay:2-out
C_1SHOT|Send_Play_Signal_When_OneShot_turns_Off:1|in=InvertShotSignal:1-out
C_ADDER|Mix_in_Shot_Off_Play_Signal:1|ninputs=2|in1=OneShotSwitch:1-out2|in2=Send_Play_Signal_When_OneShot_turns_Off:1-out
C_AND|Dont_allow_PlayTrigger_if_in_FreeMode:2|in1=c_not:2-out|in2=Mix_in_Shot_Off_Play_Signal:1-out
C_1SHOT|c_1shot:2|in=>FromModeSw:2-out
C_AND|Send_signal_if_OneShotMode_turned_On:1|in1=c_1shot:2-out|in2=OneShotPlay:2-out
C_ADDER|Mix_Play_Signal_at_Switch_to_Free_Mode:1|ninputs=2|in1=Send_signal_if_OneShotMode_turned_On:1-out|in2=Dont_allow_PlayTrigger_if_in_FreeMode:2-out
C_TO_A|PlayConvert:2|in=Mix_Play_Signal_at_Switch_to_Free_Mode:1-out
KNOB|TrimStart:2|statement=Trim Start:%3.2f%%|name=0|min=0|max=100|res=.01|default=0
C_DIVIDE|c_divide:12|in1=TrimStart:2-out|in2=100
C_MULTIPLY|c_multiply:4|in1=dlysmp2n:2-reclength|in2=c_divide:12-out
KNOB|Decay:2|statement=Decay:%3.0f%%|name=Decay|min=0|max=100|res=1|default=100
C_MULTIPLY|DecayInvert1:2|in1=Decay:2-out|in2=-1
C_ADDER|c_adder:6|ninputs=2|in1=DecayInvert1:2-out|in2=100
C_SWITCH|OneShot_not_allowed_in_free_mode:1|ninputs=2|select=>FromModeSw:2-out|in1=InvertShotSignal:1-out|in2=1
DLYSMP2N|dlysmp2n:2|numtracks=2|maxdelay=500|maxsplice=100|rectrigger=RecTrigConvert:2-out|stoptrigger=c_to_a:3-out|playtrigger=PlayConvert:2-out|looptrigger=LoopConvert:2-out|undo_redo=c_to_a:5-out|begin_mod=adc-null|end_mod=adc-null|maxlength=124.9|beginpt=c_multiply:4-out|endpt=c_multiply:3-out|dubfade=DubFade:2-out|splicelength=SpliceFade:2-out|playspeed=SpeednDirectn:2-out|decay=c_adder:6-out|loopmode=OneShot_not_allowed_in_free_mode:1-out|playmode=0|timeoutmode=1|dubmode=0|in1=In_Switch_L:2-out|in2=In_Switch_R:2-out
C_DIVIDE|Process_status_signal_for_text_trigger:1|in1=dlysmp2n:2-statusout|in2=4
C_DIVIDE|c_divide:3|in1=dlysmp2n:2-position|in2=dlysmp2n:2-reclength
C_MERGE|ClearButton_Resets_Display:2|ninputs=2|in1=c_divide:3-out|in2=Clear:2-out
HMONITOR|LoopPosition:2|in=ClearButton_Resets_Display:2-out|minimum=0.0|maximum=1.0|name=Loop Position|tag=Loop Position
TEXTKNOB|OutSelect:2|statement=Output Assign:%s|name=0|nchoices=4|default=0|choices1=1 + 2|choices2=3 + 4|choices3=5 + 6|choices4=7 + 8
KNOB|Pan1:2|statement=Pan:%1.0f|name=0|min=-50|max=50|res=1|default=0
TAPKNOB|Volume1:2|statement=Volume:%1.1f db|name=0|min=-100|max=0|steps=200|default=0|taper=3|alpha=1
C_DIVIDE|c_divide:4|in1=Pan1:2-out|in2=25
C_ADDER|c_adder:7|ninputs=2|in1=c_divide:4-out|in2=1
C_ADDER|c_adder:8|ninputs=2|in1=c_divide:4-out|in2=-1
C_ABS|PanLaw1:2|input=Pan1:2-out
C_DIVIDE|PanLaw2:2|in1=PanLaw1:2-output|in2=-16
C_ADDER|MixPanning:2|ninputs=2|in1=Volume1:2-out|in2=PanLaw2:2-out
TEXTKNOB|MuteSwitch:2|statement=B:%s|name=0|nchoices=2|default=1|choices1=Mute|choices2=Active
C_SWITCH|MuteSel:2|ninputs=2|select=MuteSwitch:2-out|in1=-100|in2=MixPanning:2-out
STEREOMIXER|stereomixer:2|ninputs=2|time_constant=20|clipvalue=10000|processoff=0|in1=dlysmp2n:2-out1|in2=dlysmp2n:2-out2|gain1=MuteSel:2-out|gain2=MuteSel:2-out|pan1=c_adder:8-out|pan2=c_adder:7-out
TEXTKNOB|FilterType:2|statement=Filter Type:%s|name=0|nchoices=3|default=0|choices1=Bypass|choices2=Lowpass|choices3=Highpass
C_TABLE|c_table:2|nentries=3|select=FilterType:2-out|in1=10|in2=8|in3=1
TAPKNOB|Q:2|statement=Q:%2.2f|name=0|min=.5|max=20|steps=300|default=.8|taper=2|alpha=1
TAPKNOB|Frequency:2|statement=Cutoff:%4.1fHz|name=0|min=20|max=20000|steps=1000|default=2700|taper=2|alpha=1
EQS|Filter_R:2|neqs=1|clipvalue=10000|in=stereomixer:2-right|processoff=0|freq1=Frequency:2-out|qfactor1=Q:2-out|boost1=0|type1=c_table:2-out
EQS|Filter_L:2|neqs=1|clipvalue=10000|in=stereomixer:2-left|processoff=0|freq1=Frequency:2-out|qfactor1=Q:2-out|boost1=0|type1=c_table:2-out
OSWITCH|LSwitch:2|numouts=4|in=Filter_L:2-out|select=OutSelect:2-out
OSWITCH|RSwitch:2|numouts=4|in=Filter_R:2-out|select=OutSelect:2-out
MENUPAGE|Sync_Pg1:2|name=B_LOOP_B|tag=0|nsubuos=8|obj1=Record_Trigger:2-obj|obj2=Clear:2-obj|obj3=Undo:2-obj|obj4=Decay:2-obj|obj5=AutoloopArm:2-obj|obj6=Beats:2-obj|obj7=OneShotPlay:2-obj|obj8=LoopPosition:2-obj
MENUPAGE|Playback:2|name=B_Playback_B|tag=0|nsubuos=8|obj1=Direction:2-obj|obj2=Speed:2-obj|obj3=TrimStart:2-obj|obj4=TrimEnd:2-obj|obj5=FilterType:2-obj|obj6=Frequency:2-obj|obj7=Q:2-obj|obj8=LoopPosition:2-obj
MENUPAGE|Mix-Details:2|name=B_Mix/Details_B|tag=0|nsubuos=7|obj1=Volume1:2-obj|obj2=Pan1:2-obj|obj3=SpliceFade:2-obj|obj4=DubFade:2-obj|obj5=InSelect:2-obj|obj6=OutSelect:2-obj|obj7=LoopPosition:2-obj
TEXTTRIGGER|Auto_Thresh_Arm_freemode:2|nstrings=2|textnum=Hitting_record_disables_Auto_threshold_record:2-out|text1=Arm Auto Thresh|text2=Armed
MENUPAGE|Free_Pg1:2|name=B_LOOP_B|tag=0|nsubuos=6|obj1=Record_Trigger:2-obj|obj2=Clear:2-obj|obj3=Undo:2-obj|obj4=Decay:2-obj|obj5=Auto_Thresh_Arm_freemode:2-obj|obj6=LoopPosition:2-obj
C_NOT|input_from_StatusOut_Freemode:2|in=dlysmp2n:2-statusout
C_ADDER|>FromAudioTrg:2|ninputs=2|in1=_AudioTrigOut>-out|in2=Record_Trigger:2-out
C_FLOP|Hitting_record_disables_Auto_threshold_record:2|reset=RecTrigAdder:2-out|set=0|toggle=Auto_Thresh_Arm_freemode:2-out
C_AND|AudioTrgIn:2|in1=Hitting_record_disables_Auto_threshold_record:2-out|in2=input_from_StatusOut_Freemode:2-out
C_COUNT2|AuTrgMath4:2|clock=>FromAudioTrg:2-out|incr=1|maxcount=AudioTrgIn:2-out|reset=Clear:2-out
C_1SHOT|AuTrgMath5:2|in=AuTrgMath4:2-out
C_ADDER|>FromStop:3|ninputs=2|in1=_midiclock>>-stop_out|in2=0
C_ADDER|>FromBeat:3|ninputs=2|in1=_midiclock>>-beat_out|in2=0
KNOB|Beats:3|statement=ReTrigger Beats:%1.f|name=0|min=2|max=128|res=1|default=8
C_SUBTRACT|c_subtract:3|in1=Beats:3-out|in2=2
C_COMPARATOR|c_comparator:3|in1=BeatCounter:3-out|in2=c_subtract:3-out
C_ADDER|Clock_Stop_In:3|ninputs=2|in1=>FromStop:3-out|in2=c_comparator:3-out
C_ADDER|Add_Reset_Signal_to_clock_signal_for_reset:2|ninputs=2|in1=>FromBeat:3-out|in2=>FromStop:3-out
C_RESET|Ignore_first_otherwise_starts_recording_on_Load:2|time=100
C_AND|Gate_for_ignore_first>>:2|in1=Add_Reset_Signal_to_clock_signal_for_reset:2-out|in2=Ignore_first_otherwise_starts_recording_on_Load:2-nout
C_COUNT2|BeatCounter:3|clock=Gate_for_ignore_first>>:2-out|incr=1|maxcount=32000|reset=Clock_Stop_In:3-out
C_CMP2|Send_signal_on_first_beat:2|in1=BeatCounter:3-out|in2=1
TEXTTRIGGER|Record_Trigger:3|nstrings=4|textnum=Process_status_signal_for_text_trigger:2-out|text1=Stop|text2=Set Loop|text3=Play|text4=Overdub
TRIGGER|Clear:3|name=CLEAR|statement=Clear|tag=Clear
C_ADDER|Record_button_mixed_here_to_increase_count:2|ninputs=3|in1=ArmSwitch:2-out|in2=Clear:3-out|in3=Record_Trigger:3-out
C_COUNT2|Counter_for_inital_auto_record_mechanism:2|clock=Record_button_mixed_here_to_increase_count:2-out|incr=1|maxcount=4|reset=Clear:3-out
C_CMP2|Only_count_first_2_beat_1_signls:2|in1=Counter_for_inital_auto_record_mechanism:2-out|in2=2
C_AND|Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:2|in1=Send_signal_on_first_beat:2-eq|in2=Only_count_first_2_beat_1_signls:2-ge
TEXTTRIGGER|AutoloopArm:3|nstrings=2|textnum=Disable_arm_on_first_loop_retrigger:2-out|text1=Arm Autoloop|text2=Armed
C_ADDER|Clear_button_Also_Disables_Autoarm:2|ninputs=2|in1=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:2-out|in2=Clear:3-out
C_FLOP|Disable_arm_on_first_loop_retrigger:2|reset=Clear_button_Also_Disables_Autoarm:2-out|set=0|toggle=AutoloopArm:3-out
C_MULTIPLY|ArmSwitch:2|in1=Send_signal_on_first_beat:2-eq|in2=Disable_arm_on_first_loop_retrigger:2-out
C_AND|Gate_open_for_1st_2_beat1_triggers:2|in1=ArmSwitch:2-out|in2=Only_count_first_2_beat_1_signls:2-le
C_ADDER|Mix_Beat_Triggers_with_record_button:2|ninputs=2|in1=Gate_open_for_1st_2_beat1_triggers:2-out|in2=Record_Trigger:3-out
C_ADDER|RecTrigAdder:3|ninputs=2|in1=Record_Trigger:3-out|in2=AuTrgMath5:3-out
C_ADDER|Mix_Free&Sync_Rec_Triggers:3|ninputs=2|in1=Mix_Beat_Triggers_with_record_button:2-out|in2=RecTrigAdder:3-out
C_TO_A|RecTrigConvert:3|in=Mix_Free&Sync_Rec_Triggers:3-out
C_TO_A|c_to_a:6|in=Clear:3-out
TEXTKNOB|OneShotPlay:3|statement=One Shot: %s|name=Direction|nchoices=2|default=0|choices1=OFF|choices2=ON
C_OSWITCH|OneShotSwitch:2|noutputs=2|select=OneShotPlay:3-out|in=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:2-out|defaultout1=0|defaultout2=0
C_ADDER|>FromModeSw:3|ninputs=2|in1=_ModeSwitch>-out|in2=0
C_NOT|c_not:3|in=>FromModeSw:3-out
C_AND|Dont_allow_loopRetrigger_if_in_FreeMode:3|in1=c_not:3-out|in2=OneShotSwitch:2-out1
C_TO_A|LoopConvert:3|in=Dont_allow_loopRetrigger_if_in_FreeMode:3-out
TEXTKNOB|Direction:3|statement=Direction: %s|name=Direction|nchoices=2|default=0|choices1=Forward|choices2=Reverse
C_TABLE|DirectionMath1:3|nentries=2|select=Direction:3-out|in1=1|in2=-1
KNOB|Speed:3|statement=Pitch:%2.0f|name=Speed|min=-60|max=0|res=1|default=0
C_ADDER|SpeedMath1:3|ninputs=2|in1=Speed:3-out|in2=60
C_TABLE|SpeedMath2:3|nentries=61|select=SpeedMath1:3-out|in1=3.125|in2=3.311|in3=3.508|in4=3.716|in5=3.938|in6=4.172|in7=4.42|in8=4.683|in9=4.961|in10=5.256|in11=5.569|in12=5.9|in13=6.25|in14=6.622|in15=7.016|in16=7.433|in17=7.875|in18=8.344|in19=8.84|in20=9.365|in21=9.92|in22=10.51|in23=11.14|in24=11.8|in25=12.5|in26=13.24|in27=14.03|in28=14.87|in29=15.75|in30=16.69|in31=17.68|in32=18.73|in33=19.84|in34=21.02|in35=22.27|in36=23.6|in37=25|in38=26.49|in39=28.06|in40=29.73|in41=31.5|in42=33.37|in43=35.36|in44=37.46|in45=39.69|in46=42.05|in47=44.55|in48=47.2|in49=50|in50=52.98|in51=56.13|in52=59.47|in53=63|in54=66.75|in55=70.71|in56=74.92|in57=79.38|in58=84.1|in59=89.1|in60=94.4|in61=100
C_MULTIPLY|SpeednDirectn:3|in1=SpeedMath2:3-out|in2=DirectionMath1:3-out
TRIGGER|Undo:3|name=Undo|statement=Undo|tag=Undo
C_TO_A|c_to_a:7|in=Undo:3-out
KNOB|TrimEnd:3|statement=Trim End:%3.2f%%|name=0|min=-100|max=0|res=.01|default=0
C_DIVIDE|c_divide:13|in1=TrimEnd:3-out|in2=100
C_MULTIPLY|c_multiply:5|in1=dlysmp2n:3-reclength|in2=c_divide:13-out
TEXTKNOB|InSelect:3|statement=Input Select:%s|name=0|nchoices=4|default=0|choices1=Input|choices2=A Loop Resamp|choices3=B Loop Resamp|choices4=D Loop Resamp
ISWITCH|In_Switch_R:3|numins=4|select=InSelect:3-out|in1=adc-in2|in2=Filter_R:1-out|in3=Filter_R:2-out|in4=Filter_R:4-out
ISWITCH|In_Switch_L:3|numins=4|select=InSelect:3-out|in1=adc-in1|in2=Filter_L:1-out|in3=Filter_L:2-out|in4=Filter_L:4-out
TAPKNOB|SpliceFade:3|statement=Splice Fade:%3.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
TAPKNOB|DubFade:3|statement=Dub Fade:%4.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
C_NOT|InvertShotSignal:2|in=OneShotPlay:3-out
C_1SHOT|Send_Play_Signal_When_OneShot_turns_Off:2|in=InvertShotSignal:2-out
C_ADDER|Mix_in_Shot_Off_Play_Signal:2|ninputs=2|in1=OneShotSwitch:2-out2|in2=Send_Play_Signal_When_OneShot_turns_Off:2-out
C_AND|Dont_allow_PlayTrigger_if_in_FreeMode:3|in1=c_not:3-out|in2=Mix_in_Shot_Off_Play_Signal:2-out
C_1SHOT|c_1shot:3|in=>FromModeSw:3-out
C_AND|Send_signal_if_OneShotMode_turned_On:2|in1=c_1shot:3-out|in2=OneShotPlay:3-out
C_ADDER|Mix_Play_Signal_at_Switch_to_Free_Mode:2|ninputs=2|in1=Send_signal_if_OneShotMode_turned_On:2-out|in2=Dont_allow_PlayTrigger_if_in_FreeMode:3-out
C_TO_A|PlayConvert:3|in=Mix_Play_Signal_at_Switch_to_Free_Mode:2-out
KNOB|TrimStart:3|statement=Trim Start:%3.2f%%|name=0|min=0|max=100|res=.01|default=0
C_DIVIDE|c_divide:14|in1=TrimStart:3-out|in2=100
C_MULTIPLY|c_multiply:6|in1=dlysmp2n:3-reclength|in2=c_divide:14-out
KNOB|Decay:3|statement=Decay:%3.0f%%|name=Decay|min=0|max=100|res=1|default=100
C_MULTIPLY|DecayInvert1:3|in1=Decay:3-out|in2=-1
C_ADDER|c_adder:9|ninputs=2|in1=DecayInvert1:3-out|in2=100
C_SWITCH|OneShot_not_allowed_in_free_mode:2|ninputs=2|select=>FromModeSw:3-out|in1=InvertShotSignal:2-out|in2=1
DLYSMP2N|dlysmp2n:3|numtracks=2|maxdelay=500|maxsplice=100|rectrigger=RecTrigConvert:3-out|stoptrigger=c_to_a:6-out|playtrigger=PlayConvert:3-out|looptrigger=LoopConvert:3-out|undo_redo=c_to_a:7-out|begin_mod=adc-null|end_mod=adc-null|maxlength=124.9|beginpt=c_multiply:6-out|endpt=c_multiply:5-out|dubfade=DubFade:3-out|splicelength=SpliceFade:3-out|playspeed=SpeednDirectn:3-out|decay=c_adder:9-out|loopmode=OneShot_not_allowed_in_free_mode:2-out|playmode=0|timeoutmode=1|dubmode=0|in1=In_Switch_L:3-out|in2=In_Switch_R:3-out
C_DIVIDE|Process_status_signal_for_text_trigger:2|in1=dlysmp2n:3-statusout|in2=4
C_DIVIDE|c_divide:5|in1=dlysmp2n:3-position|in2=dlysmp2n:3-reclength
C_MERGE|ClearButton_Resets_Display:3|ninputs=2|in1=c_divide:5-out|in2=Clear:3-out
HMONITOR|LoopPosition:3|in=ClearButton_Resets_Display:3-out|minimum=0.0|maximum=1.0|name=Loop Position|tag=Loop Position
TEXTKNOB|OutSelect:3|statement=Output Assign:%s|name=0|nchoices=4|default=0|choices1=1 + 2|choices2=3 + 4|choices3=5 + 6|choices4=7 + 8
KNOB|Pan1:3|statement=Pan:%1.0f|name=0|min=-50|max=50|res=1|default=0
TAPKNOB|Volume1:3|statement=Volume:%1.1f db|name=0|min=-100|max=0|steps=200|default=0|taper=3|alpha=1
C_DIVIDE|c_divide:6|in1=Pan1:3-out|in2=25
C_ADDER|c_adder:10|ninputs=2|in1=c_divide:6-out|in2=1
C_ADDER|c_adder:11|ninputs=2|in1=c_divide:6-out|in2=-1
C_ABS|PanLaw1:3|input=Pan1:3-out
C_DIVIDE|PanLaw2:3|in1=PanLaw1:3-output|in2=-16
C_ADDER|MixPanning:3|ninputs=2|in1=Volume1:3-out|in2=PanLaw2:3-out
TEXTKNOB|MuteSwitch:3|statement=C:%s|name=0|nchoices=2|default=1|choices1=Mute|choices2=Active
C_SWITCH|MuteSel:3|ninputs=2|select=MuteSwitch:3-out|in1=-100|in2=MixPanning:3-out
STEREOMIXER|stereomixer:3|ninputs=2|time_constant=20|clipvalue=10000|processoff=0|in1=dlysmp2n:3-out1|in2=dlysmp2n:3-out2|gain1=MuteSel:3-out|gain2=MuteSel:3-out|pan1=c_adder:11-out|pan2=c_adder:10-out
TEXTKNOB|FilterType:3|statement=Filter Type:%s|name=0|nchoices=3|default=0|choices1=Bypass|choices2=Lowpass|choices3=Highpass
C_TABLE|c_table:3|nentries=3|select=FilterType:3-out|in1=10|in2=8|in3=1
TAPKNOB|Q:3|statement=Q:%2.2f|name=0|min=.5|max=20|steps=300|default=.8|taper=2|alpha=1
TAPKNOB|Frequency:3|statement=Cutoff:%4.1fHz|name=0|min=20|max=20000|steps=1000|default=2700|taper=2|alpha=1
EQS|Filter_R:3|neqs=1|clipvalue=10000|in=stereomixer:3-right|processoff=0|freq1=Frequency:3-out|qfactor1=Q:3-out|boost1=0|type1=c_table:3-out
EQS|Filter_L:3|neqs=1|clipvalue=10000|in=stereomixer:3-left|processoff=0|freq1=Frequency:3-out|qfactor1=Q:3-out|boost1=0|type1=c_table:3-out
OSWITCH|LSwitch:3|numouts=4|in=Filter_L:3-out|select=OutSelect:3-out
OSWITCH|RSwitch:3|numouts=4|in=Filter_R:3-out|select=OutSelect:3-out
MENUPAGE|Sync_Pg1:3|name=C_LOOP_C|tag=0|nsubuos=8|obj1=Record_Trigger:3-obj|obj2=Clear:3-obj|obj3=Undo:3-obj|obj4=Decay:3-obj|obj5=AutoloopArm:3-obj|obj6=Beats:3-obj|obj7=OneShotPlay:3-obj|obj8=LoopPosition:3-obj
MENUPAGE|Playback:3|name=C_Playback_C|tag=0|nsubuos=8|obj1=Direction:3-obj|obj2=Speed:3-obj|obj3=TrimStart:3-obj|obj4=TrimEnd:3-obj|obj5=FilterType:3-obj|obj6=Frequency:3-obj|obj7=Q:3-obj|obj8=LoopPosition:3-obj
MENUPAGE|Mix-Details:3|name=C_Mix/Details_C|tag=0|nsubuos=7|obj1=Volume1:3-obj|obj2=Pan1:3-obj|obj3=SpliceFade:3-obj|obj4=DubFade:3-obj|obj5=InSelect:3-obj|obj6=OutSelect:3-obj|obj7=LoopPosition:3-obj
TEXTTRIGGER|Auto_Thresh_Arm_freemode:3|nstrings=2|textnum=Hitting_record_disables_Auto_threshold_record:3-out|text1=Arm Auto Thresh|text2=Armed
MENUPAGE|Free_Pg1:3|name=C_LOOP_C|tag=0|nsubuos=6|obj1=Record_Trigger:3-obj|obj2=Clear:3-obj|obj3=Undo:3-obj|obj4=Decay:3-obj|obj5=Auto_Thresh_Arm_freemode:3-obj|obj6=LoopPosition:3-obj
C_NOT|input_from_StatusOut_Freemode:3|in=dlysmp2n:3-statusout
C_ADDER|>FromAudioTrg:3|ninputs=2|in1=_AudioTrigOut>-out|in2=Record_Trigger:3-out
C_FLOP|Hitting_record_disables_Auto_threshold_record:3|reset=RecTrigAdder:3-out|set=0|toggle=Auto_Thresh_Arm_freemode:3-out
C_AND|AudioTrgIn:3|in1=Hitting_record_disables_Auto_threshold_record:3-out|in2=input_from_StatusOut_Freemode:3-out
C_COUNT2|AuTrgMath4:3|clock=>FromAudioTrg:3-out|incr=1|maxcount=AudioTrgIn:3-out|reset=Clear:3-out
C_1SHOT|AuTrgMath5:3|in=AuTrgMath4:3-out
C_ADDER|>FromStop:4|ninputs=2|in1=_midiclock>>-stop_out|in2=0
C_ADDER|>FromBeat:4|ninputs=2|in1=_midiclock>>-beat_out|in2=0
KNOB|Beats:4|statement=ReTrigger Beats:%1.f|name=0|min=2|max=128|res=1|default=8
C_SUBTRACT|c_subtract:4|in1=Beats:4-out|in2=2
C_COMPARATOR|c_comparator:4|in1=BeatCounter:4-out|in2=c_subtract:4-out
C_ADDER|Clock_Stop_In:4|ninputs=2|in1=>FromStop:4-out|in2=c_comparator:4-out
C_ADDER|Add_Reset_Signal_to_clock_signal_for_reset:3|ninputs=2|in1=>FromBeat:4-out|in2=>FromStop:4-out
C_RESET|Ignore_first_otherwise_starts_recording_on_Load:3|time=100
C_AND|Gate_for_ignore_first>>:3|in1=Add_Reset_Signal_to_clock_signal_for_reset:3-out|in2=Ignore_first_otherwise_starts_recording_on_Load:3-nout
C_COUNT2|BeatCounter:4|clock=Gate_for_ignore_first>>:3-out|incr=1|maxcount=32000|reset=Clock_Stop_In:4-out
C_CMP2|Send_signal_on_first_beat:3|in1=BeatCounter:4-out|in2=1
TEXTTRIGGER|Record_Trigger:4|nstrings=4|textnum=Process_status_signal_for_text_trigger:3-out|text1=Stop|text2=Set Loop|text3=Play|text4=Overdub
TRIGGER|Clear:4|name=CLEAR|statement=Clear|tag=Clear
C_ADDER|Record_button_mixed_here_to_increase_count:3|ninputs=3|in1=ArmSwitch:3-out|in2=Clear:4-out|in3=Record_Trigger:4-out
C_COUNT2|Counter_for_inital_auto_record_mechanism:3|clock=Record_button_mixed_here_to_increase_count:3-out|incr=1|maxcount=4|reset=Clear:4-out
C_CMP2|Only_count_first_2_beat_1_signls:3|in1=Counter_for_inital_auto_record_mechanism:3-out|in2=2
C_AND|Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:3|in1=Send_signal_on_first_beat:3-eq|in2=Only_count_first_2_beat_1_signls:3-ge
TEXTTRIGGER|AutoloopArm:4|nstrings=2|textnum=Disable_arm_on_first_loop_retrigger:3-out|text1=Arm Autoloop|text2=Armed
C_ADDER|Clear_button_Also_Disables_Autoarm:3|ninputs=2|in1=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:3-out|in2=Clear:4-out
C_FLOP|Disable_arm_on_first_loop_retrigger:3|reset=Clear_button_Also_Disables_Autoarm:3-out|set=0|toggle=AutoloopArm:4-out
C_MULTIPLY|ArmSwitch:3|in1=Send_signal_on_first_beat:3-eq|in2=Disable_arm_on_first_loop_retrigger:3-out
C_AND|Gate_open_for_1st_2_beat1_triggers:3|in1=ArmSwitch:3-out|in2=Only_count_first_2_beat_1_signls:3-le
C_ADDER|Mix_Beat_Triggers_with_record_button:3|ninputs=2|in1=Gate_open_for_1st_2_beat1_triggers:3-out|in2=Record_Trigger:4-out
C_ADDER|RecTrigAdder:4|ninputs=2|in1=Record_Trigger:4-out|in2=AuTrgMath5:4-out
C_ADDER|Mix_Free&Sync_Rec_Triggers:4|ninputs=2|in1=Mix_Beat_Triggers_with_record_button:3-out|in2=RecTrigAdder:4-out
C_TO_A|RecTrigConvert:4|in=Mix_Free&Sync_Rec_Triggers:4-out
C_TO_A|c_to_a:8|in=Clear:4-out
TEXTKNOB|OneShotPlay:4|statement=One Shot: %s|name=Direction|nchoices=2|default=0|choices1=OFF|choices2=ON
C_OSWITCH|OneShotSwitch:3|noutputs=2|select=OneShotPlay:4-out|in=Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:3-out|defaultout1=0|defaultout2=0
C_ADDER|>FromModeSw:4|ninputs=2|in1=_ModeSwitch>-out|in2=0
C_NOT|c_not:4|in=>FromModeSw:4-out
C_AND|Dont_allow_loopRetrigger_if_in_FreeMode:4|in1=c_not:4-out|in2=OneShotSwitch:3-out1
C_TO_A|LoopConvert:4|in=Dont_allow_loopRetrigger_if_in_FreeMode:4-out
TEXTKNOB|Direction:4|statement=Direction: %s|name=Direction|nchoices=2|default=0|choices1=Forward|choices2=Reverse
C_TABLE|DirectionMath1:4|nentries=2|select=Direction:4-out|in1=1|in2=-1
KNOB|Speed:4|statement=Pitch:%2.0f|name=Speed|min=-60|max=0|res=1|default=0
C_ADDER|SpeedMath1:4|ninputs=2|in1=Speed:4-out|in2=60
C_TABLE|SpeedMath2:4|nentries=61|select=SpeedMath1:4-out|in1=3.125|in2=3.311|in3=3.508|in4=3.716|in5=3.938|in6=4.172|in7=4.42|in8=4.683|in9=4.961|in10=5.256|in11=5.569|in12=5.9|in13=6.25|in14=6.622|in15=7.016|in16=7.433|in17=7.875|in18=8.344|in19=8.84|in20=9.365|in21=9.92|in22=10.51|in23=11.14|in24=11.8|in25=12.5|in26=13.24|in27=14.03|in28=14.87|in29=15.75|in30=16.69|in31=17.68|in32=18.73|in33=19.84|in34=21.02|in35=22.27|in36=23.6|in37=25|in38=26.49|in39=28.06|in40=29.73|in41=31.5|in42=33.37|in43=35.36|in44=37.46|in45=39.69|in46=42.05|in47=44.55|in48=47.2|in49=50|in50=52.98|in51=56.13|in52=59.47|in53=63|in54=66.75|in55=70.71|in56=74.92|in57=79.38|in58=84.1|in59=89.1|in60=94.4|in61=100
C_MULTIPLY|SpeednDirectn:4|in1=SpeedMath2:4-out|in2=DirectionMath1:4-out
TRIGGER|Undo:4|name=Undo|statement=Undo|tag=Undo
C_TO_A|c_to_a:9|in=Undo:4-out
KNOB|TrimEnd:4|statement=Trim End:%3.2f%%|name=0|min=-100|max=0|res=.01|default=0
C_DIVIDE|c_divide:15|in1=TrimEnd:4-out|in2=100
C_MULTIPLY|c_multiply:7|in1=dlysmp2n:4-reclength|in2=c_divide:15-out
TEXTKNOB|InSelect:4|statement=Input Select:%s|name=0|nchoices=4|default=0|choices1=Input|choices2=A Loop Resamp|choices3=B Loop Resamp|choices4=C Loop Resamp
ISWITCH|In_Switch_R:4|numins=4|select=InSelect:4-out|in1=adc-in2|in2=Filter_R:1-out|in3=Filter_R:2-out|in4=Filter_R:3-out
ISWITCH|In_Switch_L:4|numins=4|select=InSelect:4-out|in1=adc-in1|in2=Filter_L:1-out|in3=Filter_L:2-out|in4=Filter_L:3-out
TAPKNOB|SpliceFade:4|statement=Splice Fade:%3.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
TAPKNOB|DubFade:4|statement=Dub Fade:%4.1fms|name=0|min=0|max=100|steps=1000|default=5|taper=1|alpha=1
C_NOT|InvertShotSignal:3|in=OneShotPlay:4-out
C_1SHOT|Send_Play_Signal_When_OneShot_turns_Off:3|in=InvertShotSignal:3-out
C_ADDER|Mix_in_Shot_Off_Play_Signal:3|ninputs=2|in1=OneShotSwitch:3-out2|in2=Send_Play_Signal_When_OneShot_turns_Off:3-out
C_AND|Dont_allow_PlayTrigger_if_in_FreeMode:4|in1=c_not:4-out|in2=Mix_in_Shot_Off_Play_Signal:3-out
C_1SHOT|c_1shot:4|in=>FromModeSw:4-out
C_AND|Send_signal_if_OneShotMode_turned_On:3|in1=c_1shot:4-out|in2=OneShotPlay:4-out
C_ADDER|Mix_Play_Signal_at_Switch_to_Free_Mode:3|ninputs=2|in1=Send_signal_if_OneShotMode_turned_On:3-out|in2=Dont_allow_PlayTrigger_if_in_FreeMode:4-out
C_TO_A|PlayConvert:4|in=Mix_Play_Signal_at_Switch_to_Free_Mode:3-out
KNOB|TrimStart:4|statement=Trim Start:%3.2f%%|name=0|min=0|max=100|res=.01|default=0
C_DIVIDE|c_divide:16|in1=TrimStart:4-out|in2=100
C_MULTIPLY|c_multiply:8|in1=dlysmp2n:4-reclength|in2=c_divide:16-out
KNOB|Decay:4|statement=Decay:%3.0f%%|name=Decay|min=0|max=100|res=1|default=100
C_MULTIPLY|DecayInvert1:4|in1=Decay:4-out|in2=-1
C_ADDER|c_adder:12|ninputs=2|in1=DecayInvert1:4-out|in2=100
C_SWITCH|OneShot_not_allowed_in_free_mode:3|ninputs=2|select=>FromModeSw:4-out|in1=InvertShotSignal:3-out|in2=1
DLYSMP2N|dlysmp2n:4|numtracks=2|maxdelay=500|maxsplice=100|rectrigger=RecTrigConvert:4-out|stoptrigger=c_to_a:8-out|playtrigger=PlayConvert:4-out|looptrigger=LoopConvert:4-out|undo_redo=c_to_a:9-out|begin_mod=adc-null|end_mod=adc-null|maxlength=124.9|beginpt=c_multiply:8-out|endpt=c_multiply:7-out|dubfade=DubFade:4-out|splicelength=SpliceFade:4-out|playspeed=SpeednDirectn:4-out|decay=c_adder:12-out|loopmode=OneShot_not_allowed_in_free_mode:3-out|playmode=0|timeoutmode=1|dubmode=0|in1=In_Switch_L:4-out|in2=In_Switch_R:4-out
C_DIVIDE|Process_status_signal_for_text_trigger:3|in1=dlysmp2n:4-statusout|in2=4
C_DIVIDE|c_divide:7|in1=dlysmp2n:4-position|in2=dlysmp2n:4-reclength
C_MERGE|ClearButton_Resets_Display:4|ninputs=2|in1=c_divide:7-out|in2=Clear:4-out
HMONITOR|LoopPosition:4|in=ClearButton_Resets_Display:4-out|minimum=0.0|maximum=1.0|name=Loop Position|tag=Loop Position
TEXTKNOB|OutSelect:4|statement=Output Assign:%s|name=0|nchoices=4|default=0|choices1=1 + 2|choices2=3 + 4|choices3=5 + 6|choices4=7 + 8
KNOB|Pan1:4|statement=Pan:%1.0f|name=0|min=-50|max=50|res=1|default=0
TAPKNOB|Volume1:4|statement=Volume:%1.1f db|name=0|min=-100|max=0|steps=200|default=0|taper=3|alpha=1
C_DIVIDE|c_divide:8|in1=Pan1:4-out|in2=25
C_ADDER|c_adder:13|ninputs=2|in1=c_divide:8-out|in2=1
C_ADDER|c_adder:14|ninputs=2|in1=c_divide:8-out|in2=-1
C_ABS|PanLaw1:4|input=Pan1:4-out
C_DIVIDE|PanLaw2:4|in1=PanLaw1:4-output|in2=-16
C_ADDER|MixPanning:4|ninputs=2|in1=Volume1:4-out|in2=PanLaw2:4-out
TEXTKNOB|MuteSwitch:4|statement=D:%s|name=0|nchoices=2|default=1|choices1=Mute|choices2=Active
C_SWITCH|MuteSel:4|ninputs=2|select=MuteSwitch:4-out|in1=-100|in2=MixPanning:4-out
STEREOMIXER|stereomixer:4|ninputs=2|time_constant=20|clipvalue=10000|processoff=0|in1=dlysmp2n:4-out1|in2=dlysmp2n:4-out2|gain1=MuteSel:4-out|gain2=MuteSel:4-out|pan1=c_adder:14-out|pan2=c_adder:13-out
TEXTKNOB|FilterType:4|statement=Filter Type:%s|name=0|nchoices=3|default=0|choices1=Bypass|choices2=Lowpass|choices3=Highpass
C_TABLE|c_table:4|nentries=3|select=FilterType:4-out|in1=10|in2=8|in3=1
TAPKNOB|Q:4|statement=Q:%2.2f|name=0|min=.5|max=20|steps=300|default=.8|taper=2|alpha=1
TAPKNOB|Frequency:4|statement=Cutoff:%4.1fHz|name=0|min=20|max=20000|steps=1000|default=2700|taper=2|alpha=1
EQS|Filter_R:4|neqs=1|clipvalue=10000|in=stereomixer:4-right|processoff=0|freq1=Frequency:4-out|qfactor1=Q:4-out|boost1=0|type1=c_table:4-out
EQS|Filter_L:4|neqs=1|clipvalue=10000|in=stereomixer:4-left|processoff=0|freq1=Frequency:4-out|qfactor1=Q:4-out|boost1=0|type1=c_table:4-out
OSWITCH|LSwitch:4|numouts=4|in=Filter_L:4-out|select=OutSelect:4-out
OSWITCH|RSwitch:4|numouts=4|in=Filter_R:4-out|select=OutSelect:4-out
MENUPAGE|Sync_Pg1:4|name=D_LOOP_D|tag=0|nsubuos=8|obj1=Record_Trigger:4-obj|obj2=Clear:4-obj|obj3=Undo:4-obj|obj4=Decay:4-obj|obj5=AutoloopArm:4-obj|obj6=Beats:4-obj|obj7=OneShotPlay:4-obj|obj8=LoopPosition:4-obj
MENUPAGE|Playback:4|name=D_Playback_D|tag=0|nsubuos=8|obj1=Direction:4-obj|obj2=Speed:4-obj|obj3=TrimStart:4-obj|obj4=TrimEnd:4-obj|obj5=FilterType:4-obj|obj6=Frequency:4-obj|obj7=Q:4-obj|obj8=LoopPosition:4-obj
MENUPAGE|Mix-Details:4|name=D_Mix/Details_D|tag=0|nsubuos=7|obj1=Volume1:4-obj|obj2=Pan1:4-obj|obj3=SpliceFade:4-obj|obj4=DubFade:4-obj|obj5=InSelect:4-obj|obj6=OutSelect:4-obj|obj7=LoopPosition:4-obj
MENUPAGE|Mutes|name=Track Mutes|tag=0|nsubuos=8|obj1=MuteSwitch:1-obj|obj2=MuteSwitch:2-obj|obj3=MuteSwitch:3-obj|obj4=MuteSwitch:4-obj|obj5=LoopPosition:1-obj|obj6=LoopPosition:2-obj|obj7=LoopPosition:3-obj|obj8=LoopPosition:4-obj
MENUPAGE|MainMenu_Sync|name=0|tag=0|nsubuos=14|obj1=Global-obj|obj2=Mutes-obj|obj3=Sync_Pg1:1-obj|obj4=Playback:1-obj|obj5=Mix-Details:1-obj|obj6=Sync_Pg1:2-obj|obj7=Playback:2-obj|obj8=Mix-Details:2-obj|obj9=Sync_Pg1:3-obj|obj10=Playback:3-obj|obj11=Mix-Details:3-obj|obj12=Sync_Pg1:4-obj|obj13=Playback:4-obj|obj14=Mix-Details:4-obj
ADDER|Sum:8|ninputs=4|clipvalue=10000|in1=RSwitch:1-out4|in2=RSwitch:2-out4|in3=RSwitch:3-out4|in4=RSwitch:4-out4
ADDER|Sum:1|ninputs=4|clipvalue=10000|in1=LSwitch:1-out1|in2=LSwitch:2-out1|in3=LSwitch:3-out1|in4=LSwitch:4-out1
ADDER|Sum:3|ninputs=4|clipvalue=10000|in1=LSwitch:1-out2|in2=LSwitch:2-out2|in3=LSwitch:3-out2|in4=LSwitch:4-out2
ADDER|Sum:5|ninputs=4|clipvalue=10000|in1=LSwitch:1-out3|in2=LSwitch:2-out3|in3=LSwitch:3-out3|in4=LSwitch:4-out3
ADDER|Sum:7|ninputs=4|clipvalue=10000|in1=LSwitch:1-out4|in2=LSwitch:2-out4|in3=LSwitch:3-out4|in4=LSwitch:4-out4
ADDER|Sum:2|ninputs=4|clipvalue=10000|in1=RSwitch:1-out1|in2=RSwitch:2-out1|in3=RSwitch:3-out1|in4=RSwitch:4-out1
ADDER|Sum:4|ninputs=4|clipvalue=10000|in1=RSwitch:1-out2|in2=RSwitch:2-out2|in3=RSwitch:3-out2|in4=RSwitch:4-out2
ADDER|Sum:6|ninputs=4|clipvalue=10000|in1=RSwitch:1-out3|in2=RSwitch:2-out3|in3=RSwitch:3-out3|in4=RSwitch:4-out3
TEXTTRIGGER|Auto_Thresh_Arm_freemode:4|nstrings=2|textnum=Hitting_record_disables_Auto_threshold_record:4-out|text1=Arm Auto Thresh|text2=Armed
MENUPAGE|Free_Pg1:4|name=D_LOOP_D|tag=0|nsubuos=6|obj1=Record_Trigger:4-obj|obj2=Clear:4-obj|obj3=Undo:4-obj|obj4=Decay:4-obj|obj5=Auto_Thresh_Arm_freemode:4-obj|obj6=LoopPosition:4-obj
C_NOT|input_from_StatusOut_Freemode:4|in=dlysmp2n:4-statusout
C_ADDER|>FromAudioTrg:4|ninputs=2|in1=_AudioTrigOut>-out|in2=Record_Trigger:4-out
C_FLOP|Hitting_record_disables_Auto_threshold_record:4|reset=RecTrigAdder:4-out|set=0|toggle=Auto_Thresh_Arm_freemode:4-out
C_AND|AudioTrgIn:4|in1=Hitting_record_disables_Auto_threshold_record:4-out|in2=input_from_StatusOut_Freemode:4-out
C_COUNT2|AuTrgMath4:4|clock=>FromAudioTrg:4-out|incr=1|maxcount=AudioTrgIn:4-out|reset=Clear:4-out
C_1SHOT|AuTrgMath5:4|in=AuTrgMath4:4-out
MENUPAGE|MainMenu_Free|name=0|tag=0|nsubuos=14|obj1=Global-obj|obj2=Mutes-obj|obj3=Free_Pg1:1-obj|obj4=Playback:1-obj|obj5=Mix-Details:1-obj|obj6=Free_Pg1:2-obj|obj7=Playback:2-obj|obj8=Mix-Details:2-obj|obj9=Free_Pg1:3-obj|obj10=Playback:3-obj|obj11=Mix-Details:3-obj|obj12=Free_Pg1:4-obj|obj13=Playback:4-obj|obj14=Mix-Details:4-obj
UO_SWITCH|uo_switch:1|nsubuos=2|in=_ModeSwitch>-out|subuos1=MainMenu_Sync-obj|subuos2=MainMenu_Free-obj
TAIL|sdg
adc| ;=30,30,100,0
_midiclock>>| ;=48,144,100,0
>FromStop:1| ;=424,168,100,0
>FromBeat:1| ;=424,280,100,0
Beats:1| ;=632,472,100,0
c_subtract:1| ;=648,600,100,0
c_comparator:1| ;=784,568,100,0
Clock_Stop_In:1| ;=880,340,100,0
Add_Reset_Signal_to_clock_signal_for_reset| ;=872,224,100,0
Ignore_first_otherwise_starts_recording_on_Load| ;=880,460,100,0
Gate_for_ignore_first>>| ;=1020,220,100,0
BeatCounter:1| ;=1160,220,100,0
Send_signal_on_first_beat| ;=1300,220,100,0
Record_Trigger:1| ;=2980,1980,100,0
Clear:1| ;=736,1288,100,0
Record_button_mixed_here_to_increase_count| ;=872,1288,100,0
Counter_for_inital_auto_record_mechanism| ;=1016,1288,100,0
Only_count_first_2_beat_1_signls| ;=1152,1288,100,0
Once_first_2_beat_1_signals_have_played_allow_loop_retrigger| ;=1296,1288,100,0
AutoloopArm:1| ;=872,1544,100,0
Clear_button_Also_Disables_Autoarm| ;=872,1424,100,0
Disable_arm_on_first_loop_retrigger| ;=1016,1424,100,0
ArmSwitch| ;=1440,220,100,0
Gate_open_for_1st_2_beat1_triggers| ;=1580,220,100,0
Mix_Beat_Triggers_with_record_button| ;=1720,220,100,0
RecTrigAdder:1| ;=3120,1980,100,0
Mix_Free&Sync_Rec_Triggers:1| ;=1860,220,100,0
RecTrigConvert:1| ;=2000,200,100,0
c_to_a:2| ;=2000,320,100,0
OneShotPlay:1| ;=1296,1168,100,0
OneShotSwitch| ;=1432,1168,100,0
_ModeSwitch>| ;=3816,1192,100,0
>FromModeSw:1| ;=424,392,100,0
c_not:1| ;=1432,1048,100,0
Dont_allow_loopRetrigger_if_in_FreeMode:1| ;=1576,1048,100,0
LoopConvert:1| ;=2000,560,100,0
Direction:1| ;=2980,460,100,0
DirectionMath1:1| ;=3120,680,100,0
Speed:1| ;=2840,800,100,0
SpeedMath1:1| ;=2980,820,100,0
SpeedMath2:1| ;=3120,800,100,0
SpeednDirectn:1| ;=3260,680,100,0
Undo:1| ;=2980,2220,100,0
c_to_a:4| ;=2000,680,100,0
TrimEnd:1| ;=2980,700,100,0
c_divide:9| ;=3120,1040,100,0
c_multiply:1| ;=3260,1040,100,0
InSelect:1| ;=1860,100,100,0
In_Switch_R:1| ;=2000,800,100,0
In_Switch_L:1| ;=2000,20,100,0
SpliceFade:1| ;=2980,1400,100,0
DubFade:1| ;=2980,1860,100,0
InvertShotSignal| ;=1432,1328,100,0
Send_Play_Signal_When_OneShot_turns_Off| ;=1576,1328,100,0
Mix_in_Shot_Off_Play_Signal| ;=1712,1328,100,0
Dont_allow_PlayTrigger_if_in_FreeMode:1| ;=1856,1328,100,0
c_1shot:1| ;=1712,1448,100,0
Send_signal_if_OneShotMode_turned_On| ;=1856,1448,100,0
Mix_Play_Signal_at_Switch_to_Free_Mode| ;=1992,1328,100,0
PlayConvert:1| ;=2000,440,100,0
TrimStart:1| ;=2980,580,100,0
c_divide:10| ;=3120,920,100,0
c_multiply:2| ;=3260,920,100,0
Decay:1| ;=2980,2340,100,0
DecayInvert1:1| ;=3120,2340,100,0
c_adder:3| ;=3260,2340,100,0
OneShot_not_allowed_in_free_mode| ;=1576,1448,100,0
dlysmp2n:1| ;=2280,1136,100,0
Process_status_signal_for_text_trigger| ;=2840,1980,100,0
c_divide:1| ;=2584,624,100,0
ClearButton_Resets_Display:1| ;=2696,656,100,0
LoopPosition:1| ;=3384,672,100,0
OutSelect:1| ;=3240,88,100,0
Pan1:1| ;=2700,1500,100,0
Volume1:1| ;=2980,1280,100,0
c_divide:2| ;=2840,1620,100,0
c_adder:4| ;=2980,1620,100,0
c_adder:5| ;=2980,1740,100,0
PanLaw1:1| ;=2840,1500,100,0
PanLaw2:1| ;=2980,1520,100,0
MixPanning:1| ;=3120,1500,100,0
MuteSwitch:1| ;=3384,560,100,0
MuteSel:1| ;=2400,112,100,0
stereomixer:1| ;=2560,20,100,0
FilterType:1| ;=2980,920,100,0
c_table:1| ;=3120,1160,100,0
Q:1| ;=2980,1040,100,0
Frequency:1| ;=2980,240,100,0
Filter_R:1| ;=3120,240,100,0
Filter_L:1| ;=3120,20,100,0
LSwitch:1| ;=3384,24,100,0
RSwitch:1| ;=3384,160,100,0
Sync_Pg1:1| ;=3384,312,100,0
Playback:1| ;=3120,460,100,0
Mix-Details:1| ;=3376,1224,100,0
Global_Threshold:1| ;=40,720,100,0
Global| ;=4008,1576,100,0
Auto_Thresh_Arm_freemode:1| ;=3120,2100,100,0
Free_Pg1:1| ;=3376,1464,100,0
input_from_StatusOut_Freemode:1| ;=3260,2120,100,0
In_from_ADC:1| ;=40,456,100,0
AuTrgMath1:1| ;=40,576,100,0
_AudioTrigOut>| ;=40,840,100,0
>FromAudioTrg:1| ;=424,512,100,0
Hitting_record_disables_Auto_threshold_record:1| ;=3256,1992,100,0
AudioTrgIn:1| ;=3400,1980,100,0
AuTrgMath4:1| ;=872,1664,100,0
AuTrgMath5:1| ;=2980,2100,100,0
>FromStop:2| ;=424,2736,100,0
>FromBeat:2| ;=424,2848,100,0
Beats:2| ;=632,3040,100,0
c_subtract:2| ;=648,3168,100,0
c_comparator:2| ;=784,3136,100,0
Clock_Stop_In:2| ;=880,2904,100,0
Add_Reset_Signal_to_clock_signal_for_reset:1| ;=872,2792,100,0
Ignore_first_otherwise_starts_recording_on_Load:1| ;=880,3024,100,0
Gate_for_ignore_first>>:1| ;=1016,2784,100,0
BeatCounter:2| ;=1160,2784,100,0
Send_signal_on_first_beat:1| ;=1296,2784,100,0
Record_Trigger:2| ;=2976,4544,100,0
Clear:2| ;=736,3856,100,0
Record_button_mixed_here_to_increase_count:1| ;=872,3856,100,0
Counter_for_inital_auto_record_mechanism:1| ;=1016,3856,100,0
Only_count_first_2_beat_1_signls:1| ;=1152,3856,100,0
Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:1| ;=1296,3856,100,0
AutoloopArm:2| ;=872,4112,100,0
Clear_button_Also_Disables_Autoarm:1| ;=872,3992,100,0
Disable_arm_on_first_loop_retrigger:1| ;=1016,3992,100,0
ArmSwitch:1| ;=1440,2784,100,0
Gate_open_for_1st_2_beat1_triggers:1| ;=1576,2784,100,0
Mix_Beat_Triggers_with_record_button:1| ;=1720,2784,100,0
RecTrigAdder:2| ;=3120,4544,100,0
Mix_Free&Sync_Rec_Triggers:2| ;=1856,2784,100,0
RecTrigConvert:2| ;=2000,2768,100,0
c_to_a:3| ;=2000,2888,100,0
OneShotPlay:2| ;=1296,3736,100,0
OneShotSwitch:1| ;=1432,3736,100,0
>FromModeSw:2| ;=424,2960,100,0
c_not:2| ;=1432,3616,100,0
Dont_allow_loopRetrigger_if_in_FreeMode:2| ;=1576,3616,100,0
LoopConvert:2| ;=2000,3128,100,0
Direction:2| ;=2976,3024,100,0
DirectionMath1:2| ;=3120,3248,100,0
Speed:2| ;=2840,3368,100,0
SpeedMath1:2| ;=2976,3384,100,0
SpeedMath2:2| ;=3120,3368,100,0
SpeednDirectn:2| ;=3256,3248,100,0
Undo:2| ;=2976,4784,100,0
c_to_a:5| ;=2000,3248,100,0
TrimEnd:2| ;=2976,3264,100,0
c_divide:11| ;=3120,3608,100,0
c_multiply:3| ;=3256,3608,100,0
InSelect:2| ;=1856,2664,100,0
In_Switch_R:2| ;=2000,3368,100,0
In_Switch_L:2| ;=2000,2584,100,0
SpliceFade:2| ;=2976,3968,100,0
DubFade:2| ;=2976,4424,100,0
InvertShotSignal:1| ;=1432,3896,100,0
Send_Play_Signal_When_OneShot_turns_Off:1| ;=1576,3896,100,0
Mix_in_Shot_Off_Play_Signal:1| ;=1712,3896,100,0
Dont_allow_PlayTrigger_if_in_FreeMode:2| ;=1856,3896,100,0
c_1shot:2| ;=1712,4016,100,0
Send_signal_if_OneShotMode_turned_On:1| ;=1856,4016,100,0
Mix_Play_Signal_at_Switch_to_Free_Mode:1| ;=1992,3896,100,0
PlayConvert:2| ;=2000,3008,100,0
TrimStart:2| ;=2976,3144,100,0
c_divide:12| ;=3120,3488,100,0
c_multiply:4| ;=3256,3488,100,0
Decay:2| ;=2976,4904,100,0
DecayInvert1:2| ;=3120,4904,100,0
c_adder:6| ;=3256,4904,100,0
OneShot_not_allowed_in_free_mode:1| ;=1576,4016,100,0
dlysmp2n:2| ;=2280,3704,100,0
Process_status_signal_for_text_trigger:1| ;=2840,4544,100,0
c_divide:3| ;=2584,3192,100,0
ClearButton_Resets_Display:2| ;=2696,3224,100,0
LoopPosition:2| ;=3384,3240,100,0
OutSelect:2| ;=3240,2656,100,0
Pan1:2| ;=2696,4064,100,0
Volume1:2| ;=2976,3848,100,0
c_divide:4| ;=2840,4184,100,0
c_adder:7| ;=2976,4184,100,0
c_adder:8| ;=2976,4304,100,0
PanLaw1:2| ;=2840,4064,100,0
PanLaw2:2| ;=2976,4088,100,0
MixPanning:2| ;=3120,4064,100,0
MuteSwitch:2| ;=3384,3128,100,0
MuteSel:2| ;=2400,2680,100,0
stereomixer:2| ;=2560,2584,100,0
FilterType:2| ;=2976,3488,100,0
c_table:2| ;=3120,3728,100,0
Q:2| ;=2976,3608,100,0
Frequency:2| ;=2976,2808,100,0
Filter_R:2| ;=3120,2808,100,0
Filter_L:2| ;=3120,2584,100,0
LSwitch:2| ;=3384,2592,100,0
RSwitch:2| ;=3384,2728,100,0
Sync_Pg1:2| ;=3384,2880,100,0
Playback:2| ;=3120,3024,100,0
Mix-Details:2| ;=3376,3792,100,0
Auto_Thresh_Arm_freemode:2| ;=3120,4664,100,0
Free_Pg1:2| ;=3376,4032,100,0
input_from_StatusOut_Freemode:2| ;=3256,4688,100,0
>FromAudioTrg:2| ;=424,3080,100,0
Hitting_record_disables_Auto_threshold_record:2| ;=3256,4560,100,0
AudioTrgIn:2| ;=3400,4544,100,0
AuTrgMath4:2| ;=872,4232,100,0
AuTrgMath5:2| ;=2976,4664,100,0
>FromStop:3| ;=288,5352,100,0
>FromBeat:3| ;=288,5464,100,0
Beats:3| ;=496,5656,100,0
c_subtract:3| ;=512,5784,100,0
c_comparator:3| ;=648,5752,100,0
Clock_Stop_In:3| ;=744,5528,100,0
Add_Reset_Signal_to_clock_signal_for_reset:2| ;=736,5408,100,0
Ignore_first_otherwise_starts_recording_on_Load:2| ;=744,5648,100,0
Gate_for_ignore_first>>:2| ;=880,5408,100,0
BeatCounter:3| ;=1024,5408,100,0
Send_signal_on_first_beat:2| ;=1160,5408,100,0
Record_Trigger:3| ;=2840,7168,100,0
Clear:3| ;=600,6472,100,0
Record_button_mixed_here_to_increase_count:2| ;=736,6472,100,0
Counter_for_inital_auto_record_mechanism:2| ;=880,6472,100,0
Only_count_first_2_beat_1_signls:2| ;=1016,6472,100,0
Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:2| ;=1160,6472,100,0
AutoloopArm:3| ;=736,6728,100,0
Clear_button_Also_Disables_Autoarm:2| ;=736,6608,100,0
Disable_arm_on_first_loop_retrigger:2| ;=880,6608,100,0
ArmSwitch:2| ;=1304,5408,100,0
Gate_open_for_1st_2_beat1_triggers:2| ;=1440,5408,100,0
Mix_Beat_Triggers_with_record_button:2| ;=1584,5408,100,0
RecTrigAdder:3| ;=2984,7168,100,0
Mix_Free&Sync_Rec_Triggers:3| ;=1720,5408,100,0
RecTrigConvert:3| ;=1864,5384,100,0
c_to_a:6| ;=1864,5504,100,0
OneShotPlay:3| ;=1160,6352,100,0
OneShotSwitch:2| ;=1296,6352,100,0
>FromModeSw:3| ;=288,5576,100,0
c_not:3| ;=1296,6232,100,0
Dont_allow_loopRetrigger_if_in_FreeMode:3| ;=1440,6232,100,0
LoopConvert:3| ;=1864,5744,100,0
Direction:3| ;=2840,5648,100,0
DirectionMath1:3| ;=2984,5864,100,0
Speed:3| ;=2704,5984,100,0
SpeedMath1:3| ;=2840,6008,100,0
SpeedMath2:3| ;=2984,5984,100,0
SpeednDirectn:3| ;=3120,5864,100,0
Undo:3| ;=2840,7408,100,0
c_to_a:7| ;=1864,5864,100,0
TrimEnd:3| ;=2840,5888,100,0
c_divide:13| ;=2984,6224,100,0
c_multiply:5| ;=3120,6224,100,0
InSelect:3| ;=1720,5288,100,0
In_Switch_R:3| ;=1864,5984,100,0
In_Switch_L:3| ;=1864,5208,100,0
SpliceFade:3| ;=2840,6584,100,0
DubFade:3| ;=2840,7048,100,0
InvertShotSignal:2| ;=1296,6512,100,0
Send_Play_Signal_When_OneShot_turns_Off:2| ;=1440,6512,100,0
Mix_in_Shot_Off_Play_Signal:2| ;=1576,6512,100,0
Dont_allow_PlayTrigger_if_in_FreeMode:3| ;=1720,6512,100,0
c_1shot:3| ;=1576,6632,100,0
Send_signal_if_OneShotMode_turned_On:2| ;=1720,6632,100,0
Mix_Play_Signal_at_Switch_to_Free_Mode:2| ;=1856,6512,100,0
PlayConvert:3| ;=1864,5624,100,0
TrimStart:3| ;=2840,5768,100,0
c_divide:14| ;=2984,6104,100,0
c_multiply:6| ;=3120,6104,100,0
Decay:3| ;=2840,7528,100,0
DecayInvert1:3| ;=2984,7528,100,0
c_adder:9| ;=3120,7528,100,0
OneShot_not_allowed_in_free_mode:2| ;=1440,6632,100,0
dlysmp2n:3| ;=2144,6320,100,0
Process_status_signal_for_text_trigger:2| ;=2704,7168,100,0
c_divide:5| ;=2448,5808,100,0
ClearButton_Resets_Display:3| ;=2560,5840,100,0
LoopPosition:3| ;=3248,5856,100,0
OutSelect:3| ;=3104,5272,100,0
Pan1:3| ;=2560,6688,100,0
Volume1:3| ;=2840,6464,100,0
c_divide:6| ;=2704,6808,100,0
c_adder:10| ;=2840,6808,100,0
c_adder:11| ;=2840,6928,100,0
PanLaw1:3| ;=2704,6688,100,0
PanLaw2:3| ;=2840,6704,100,0
MixPanning:3| ;=2984,6688,100,0
MuteSwitch:3| ;=3248,5744,100,0
MuteSel:3| ;=2264,5296,100,0
stereomixer:3| ;=2424,5208,100,0
FilterType:3| ;=2840,6104,100,0
c_table:3| ;=2984,6344,100,0
Q:3| ;=2840,6224,100,0
Frequency:3| ;=2840,5424,100,0
Filter_R:3| ;=2984,5424,100,0
Filter_L:3| ;=2984,5208,100,0
LSwitch:3| ;=3248,5208,100,0
RSwitch:3| ;=3248,5344,100,0
Sync_Pg1:3| ;=3248,5496,100,0
Playback:3| ;=2984,5648,100,0
Mix-Details:3| ;=3240,6408,100,0
Auto_Thresh_Arm_freemode:3| ;=2984,7288,100,0
Free_Pg1:3| ;=3240,6648,100,0
input_from_StatusOut_Freemode:3| ;=3120,7304,100,0
>FromAudioTrg:3| ;=288,5696,100,0
Hitting_record_disables_Auto_threshold_record:3| ;=3120,7176,100,0
AudioTrgIn:3| ;=3264,7168,100,0
AuTrgMath4:3| ;=736,6848,100,0
AuTrgMath5:3| ;=2840,7288,100,0
>FromStop:4| ;=288,7920,100,0
>FromBeat:4| ;=288,8032,100,0
Beats:4| ;=496,8224,100,0
c_subtract:4| ;=512,8352,100,0
c_comparator:4| ;=648,8320,100,0
Clock_Stop_In:4| ;=744,8088,100,0
Add_Reset_Signal_to_clock_signal_for_reset:3| ;=736,7976,100,0
Ignore_first_otherwise_starts_recording_on_Load:3| ;=744,8208,100,0
Gate_for_ignore_first>>:3| ;=880,7968,100,0
BeatCounter:4| ;=1024,7968,100,0
Send_signal_on_first_beat:3| ;=1160,7968,100,0
Record_Trigger:4| ;=2840,9728,100,0
Clear:4| ;=600,9040,100,0
Record_button_mixed_here_to_increase_count:3| ;=736,9040,100,0
Counter_for_inital_auto_record_mechanism:3| ;=880,9040,100,0
Only_count_first_2_beat_1_signls:3| ;=1016,9040,100,0
Once_first_2_beat_1_signals_have_played_allow_loop_retrigger:3| ;=1160,9040,100,0
AutoloopArm:4| ;=736,9296,100,0
Clear_button_Also_Disables_Autoarm:3| ;=736,9176,100,0
Disable_arm_on_first_loop_retrigger:3| ;=880,9176,100,0
ArmSwitch:3| ;=1304,7968,100,0
Gate_open_for_1st_2_beat1_triggers:3| ;=1440,7968,100,0
Mix_Beat_Triggers_with_record_button:3| ;=1584,7968,100,0
RecTrigAdder:4| ;=2984,9728,100,0
Mix_Free&Sync_Rec_Triggers:4| ;=1720,7968,100,0
RecTrigConvert:4| ;=1864,7952,100,0
c_to_a:8| ;=1864,8072,100,0
OneShotPlay:4| ;=1160,8920,100,0
OneShotSwitch:3| ;=1296,8920,100,0
>FromModeSw:4| ;=288,8144,100,0
c_not:4| ;=1296,8800,100,0
Dont_allow_loopRetrigger_if_in_FreeMode:4| ;=1440,8800,100,0
LoopConvert:4| ;=1864,8312,100,0
Direction:4| ;=2840,8208,100,0
DirectionMath1:4| ;=2984,8432,100,0
Speed:4| ;=2704,8552,100,0
SpeedMath1:4| ;=2840,8568,100,0
SpeedMath2:4| ;=2984,8552,100,0
SpeednDirectn:4| ;=3120,8432,100,0
Undo:4| ;=2840,9968,100,0
c_to_a:9| ;=1864,8432,100,0
TrimEnd:4| ;=2840,8448,100,0
c_divide:15| ;=2984,8792,100,0
c_multiply:7| ;=3120,8792,100,0
InSelect:4| ;=1720,7848,100,0
In_Switch_R:4| ;=1864,8552,100,0
In_Switch_L:4| ;=1864,7768,100,0
SpliceFade:4| ;=2840,9152,100,0
DubFade:4| ;=2840,9608,100,0
InvertShotSignal:3| ;=1296,9080,100,0
Send_Play_Signal_When_OneShot_turns_Off:3| ;=1440,9080,100,0
Mix_in_Shot_Off_Play_Signal:3| ;=1576,9080,100,0
Dont_allow_PlayTrigger_if_in_FreeMode:4| ;=1720,9080,100,0
c_1shot:4| ;=1576,9200,100,0
Send_signal_if_OneShotMode_turned_On:3| ;=1720,9200,100,0
Mix_Play_Signal_at_Switch_to_Free_Mode:3| ;=1856,9080,100,0
PlayConvert:4| ;=1864,8192,100,0
TrimStart:4| ;=2840,8328,100,0
c_divide:16| ;=2984,8672,100,0
c_multiply:8| ;=3120,8672,100,0
Decay:4| ;=2840,10088,100,0
DecayInvert1:4| ;=2984,10088,100,0
c_adder:12| ;=3120,10088,100,0
OneShot_not_allowed_in_free_mode:3| ;=1440,9200,100,0
dlysmp2n:4| ;=2144,8888,100,0
Process_status_signal_for_text_trigger:3| ;=2704,9728,100,0
c_divide:7| ;=2448,8376,100,0
ClearButton_Resets_Display:4| ;=2560,8408,100,0
LoopPosition:4| ;=3248,8424,100,0
OutSelect:4| ;=3104,7840,100,0
Pan1:4| ;=2560,9248,100,0
Volume1:4| ;=2840,9032,100,0
c_divide:8| ;=2704,9368,100,0
c_adder:13| ;=2840,9368,100,0
c_adder:14| ;=2840,9488,100,0
PanLaw1:4| ;=2704,9248,100,0
PanLaw2:4| ;=2840,9272,100,0
MixPanning:4| ;=2984,9248,100,0
MuteSwitch:4| ;=3248,8312,100,0
MuteSel:4| ;=2264,7864,100,0
stereomixer:4| ;=2424,7768,100,0
FilterType:4| ;=2840,8672,100,0
c_table:4| ;=2984,8912,100,0
Q:4| ;=2840,8792,100,0
Frequency:4| ;=2840,7992,100,0
Filter_R:4| ;=2984,7992,100,0
Filter_L:4| ;=2984,7768,100,0
LSwitch:4| ;=3248,7776,100,0
RSwitch:4| ;=3248,7912,100,0
Sync_Pg1:4| ;=3248,8064,100,0
Playback:4| ;=2984,8208,100,0
Mix-Details:4| ;=3240,8976,100,0
Mutes| ;=3824,2064,100,0
MainMenu_Sync| ;=3816,1416,100,0
Sum:8| ;=3820,1000,100,0
Sum:1| ;=3820,20,100,0
Sum:3| ;=3820,160,100,0
Sum:5| ;=3820,300,100,0
Sum:7| ;=3820,440,100,0
Sum:2| ;=3820,580,100,0
Sum:4| ;=3820,720,100,0
Sum:6| ;=3820,860,100,0
Auto_Thresh_Arm_freemode:4| ;=2984,9848,100,0
Free_Pg1:4| ;=3240,9216,100,0
input_from_StatusOut_Freemode:4| ;=3120,9872,100,0
>FromAudioTrg:4| ;=288,8264,100,0
Hitting_record_disables_Auto_threshold_record:4| ;=3120,9744,100,0
AudioTrgIn:4| ;=3264,9728,100,0
AuTrgMath4:4| ;=736,9416,100,0
AuTrgMath5:4| ;=2840,9848,100,0
MainMenu_Free| ;=3824,1728,100,0
uo_switch:1| ;=4016,1280,100,0
tail|
