Home Forums Products Stompboxes Expression pedal suddenly doesn’t work Reply To: Expression pedal suddenly doesn’t work
#163794
DrBB
    The problem is that the Space just suddenly acted like I’d disconnected the expression pedal–like there’s no expression pedal connected at all. Thought it was the pedal itself, so got a new one, but same result: Space simply doesn’t recognize it’s connected. This is after years of using the same M-Audio exp pedal, same set-up. Maybe it’s the jack? Except the jack does take information from my (Ernie Ball VPjr) volume pedal. I tried alcohol swabbing the jack, but no joy there either.
    I have connected to the Space via the desktop H9 Controller app, but I’m not seeing the automatic calibration setting you refer to. I’ve attached a screen shot of the control panel I’m seeing. I’m also wondering if there’s a way to just reset to original factory settings? I thought I’d seen that somewhere in the past but I’m not finding it now.
    So frustrating.
    Screen Shot 2022-05-19 at 12.05.55 PM
