Home Forums Products Stompboxes H9 bricked Reply To: H9 bricked
#164149
david_chat
    got ya.
    eventide support sent me this and thankfully it worked in my situation. 👇
    Jerome Hyman commented:
    I would recommend trying the update again with the Eventide Direct Updater on a computer via a USB connection. The application is available at the following links:
    Mac OS   https://www.eventideaudio.com/downloads?id=101109
    Windows https://www.eventideaudio.com/downloads?id=101088
    Get the unit into Update Mode by powering it up while holding down the HotKnob button at the top left of the unit. If successful, you will see UPDATE on the display. If you can do that, then please try to update the software on the unit to see if it helps. Make sure you are using the Eventide power supply when attempting the update. Let me know what happens.
