Home Forums Products Stompboxes Tape Echo algorithm is two in parallel right? Reply To: Tape Echo algorithm is two in parallel right?
#164743
joecozzi
    Hi Chalky,
    Yes,  the delays are in parallel. The only way to sort of run them in series is if the Delay Mix A + B is set in the middle and you physically run a cable out of  Out 1 to In 2 to make a series ping / pong kinda thing externally. There is no in-algorithm control for series functionality.
