Reply To: H9 and HX Stomp
Home Forums Products Stompboxes H9 and HX Stomp Reply To: H9 and HX Stomp
#165013
joecozzi
If in isolation the H9 works as intended, it leads me to believe the problem lies with the Stomp. Have you tried starting a preset from scratch? I would simply create a signal flow with out amps or effects that engages the loop. Make sure all global EQ’s and dynamics are turned off.
