Home › Forums › Products › Eurorack Modules › Misha: input function mapping not working? › Reply To: Misha: input function mapping not working?
August 16, 2022 at 2:59 pm
#165043
When you say “reset the sequence” do you mean play it from the beginning? If you’d like to trigger this function, you can do so be using the trigger mapping Type > Special and Action > Play. In this scenario, the trigger source will play a sequence that is not currently playing, or play it from the beginning if it is already playing.
The Reset Seq action is for resetting the sequences play modifiers and resets the sequence to the following:
- 1) undo “INVERT” if it’s inverted
- 2) set to ‘prime’ if not there, and
- 3) reset interval sequence to +1
Let me know if that clears things up for you.
