Home › Forums › Products › Stompboxes › H90 Dual Routing Questions › Reply To: H90 Dual Routing Questions
#166431
joecozzi
    It’s a per Program setting. Each program can have its individual routing and algorithm organization. The main thing you have to understand is once the pedal is in global Dual mode, these same programs will not be available if the pedal is switched to Insert Mode.
