Home Forums Products Stompboxes USING THE H90 AS A MIDI CONTROLLER TO CHANNEL SWITCH AN AMP … Reply To: USING THE H90 AS A MIDI CONTROLLER TO CHANNEL SWITCH AN AMP …
#166696
    Thus, I assume that the H90 does not generate and transmit MIDI commands when one steps on any of the three footswitches on the H90 itself. Can anyone confirm that assumption?
    This is correct. Currently, you cannot transmit the H90’s internal controllers such as a HotKnob or HotSwitch as a MIDI CC, you can only map an external controller (expression pedal or aux switch) as a CC.
    Yes, your proposed example should work with the correct MIDI transmit and global mappings for the aux switch. Cool idea!
