Home › Forums › Products › Stompboxes › H90 Looper question › Reply To: H90 Looper question
November 17, 2022 at 8:03 pm
#166810
60 seconds is great, although I don’t think it will 100% fit my needs …
I hadn’t strayed away from the 2x 60 second max since I got the H90. You inspired a little experiment. Maybe I can get you 40-80% there.
[Disclaimer: Monitoring through 2 Vox guitar amps and/or Sennheiser ‘phones; not flat nearfields, as yet]
- (+/-) 1X @2 minutes: Nothing wrong with this. Very little tradeoff – if any.
- (+/-) 1/2X @ 4 minutes: Surprisingly, not a huge compromise here, either. Especially if followed by most any kind of post-processing.
- (+/-) 1/4X @ 8 minutes: Special FX territory. Robots on ham radios.
- Bonus Fun: Map the Speed parameters above to an expression pedal.
It may be a nice future-feature to export / import the looper data in & out to USB, or (more probably), in & out of the H90 Control app. You could slide around that limitation now with a cumbersome workaround. I can see where import / export might be quite useful, especially, for example, as one of two processors.
