Home › Forums › Products › Stompboxes › infinite repeat with reverse. › Reply To: infinite repeat with reverse.
November 25, 2022 at 1:59 pm
#167106
here you can see that the loop starts to fade out to quiet as soon as phi is pressed, but it stills plays in the background, so it’s as if the loop is in hold mode as it should be but somehow the pedal won’t hold it on the initial sound level.
