Home › Forums › Products › Stompboxes › H90 CONTROL APP COPY / PASTE BUG? › Reply To: H90 CONTROL APP COPY / PASTE BUG?
November 28, 2022 at 10:51 am
#167174
Hi rockstar. I just tested starting with an INIT Program and adding Prism Shift to Slot A. Then, I copied like you described. Afterwards, I proceeded to click the 3 dots to paste into the default Thru algorithm on Slot B and it worked as intended, it copied the exact Prism Shift algorithm and its settings. Looks like it already does what you wan it to do and I did this without renaming anything beforehand. I’m not sure why Control is behaving differently for you. I’m on v1.0.0 and software 1.1.4.61 on the pedal.
