Home › Forums › Products › Stompboxes › Split: Split: Changing Presets via MIDI › Reply To: Split: Split: Changing Presets via MIDI
November 29, 2022 at 11:15 pm
#167269
If what you mean is that you can’t change to a different preset within a Program via MIDI, then you are correct; however, all aspects of both presets within a Program can be manipulated via MIDI. All of them. With that being said, with true spillover, what is the complication of just switching to a new program with varying presets if it’s seamless?
Since I was hoping to replace a delay and reverb, unless I’m not thinking about it correctly, I’d have to set up programs like this if I want to change reverbs without changing delays:
- Short Hall
- .8th delay
- 8th delay
- 8th into .8th delay
- .8th into 1/4 delay
- 1/4 delay
- Modulated Plate
- .8th delay
- 8th delay
- 1/4 delay
Is there a better way to do it?
