Home › Forums › Products › Stompboxes › Split: Split: Changing Presets via MIDI › Reply To: Split: Split: Changing Presets via MIDI
#167279
joecozzi
    Ok, now that I understand what you mean, let’s look at this way. In your example, you have 8 programs.
    Short Hall &.8th delay
    Short Hall & 8th delay
    Short Hall & 8th into .8th delay
    Short Hall & .8th into 1/4 delay
    Short Hall & 1/4 delay
    Modulated Plate & .8th delay
    Modulated Plate & 8th delay
    Modulated Plate & 8th into .8th delay
    Modulated Plate & .8th into 1/4 delay
    Modulated Plate & 1/4 delay
    As you switch from one program to the next, the reverb will stay constant, but the delay trails of the previous program will continue to trail out as you play along with the subdivision of the new delay time. It’s actually more seamless than switching to a different delay preset which would cause the delay to immediately change subdivisions as it’s trailing out.
