Home Forums Products Stompboxes Split: H90 Insert Feedback Reply To: Split: H90 Insert Feedback
#167311
brockstar
    While we’re on the subject of this insert stuff. Is parallel path suppose to be louder in volume? I get a bit of a volume jump when moving my insert to parallel path compared to being in pre / mid / post, maybe that is normal or no?
    Maybe this has something to do with the feedback issue as well or something to look into as well.
    Try this:
    Put a pedal in insert 1, turn insert 1 off, and also turn off preset A and preset B and now move the insert 1 block around between pre / parallel / mid / post and you’ll hear that parallel is a bit louder.
