Reply To: Split: Split: Changing Presets via MIDI
Home Forums Products Stompboxes Split: Split: Changing Presets via MIDI Reply To: Split: Split: Changing Presets via MIDI
#167328
joecozzi
Yes, it is a serial delay, but the algorithm is unique in that even though it’s a serial delay, the delays are individually panned to separate outputs. Not so in mono, but the serial test is obvious when you set a long delay time for A and short delay time for B; we don’t hear B until A’s delay time is completed.
