Home Forums Products Stompboxes Split: Split: Changing Presets via MIDI Reply To: Split: Split: Changing Presets via MIDI
#167346
joecozzi
    Just to further add to apalazzolo’s great ideas, the H90 also features three hotswitches in PERFORM mode, so you can achieve up to three different delay subdivision settings per Program. In fact, if you wanted to, each Hotswitch can change any set of parameters across the entire Program (both algorithms) instantaneously. Using them in combination with Aux switches is very powerful.
