Home › Forums › Products › Stompboxes › H90 Footswitch wiring spa › Reply To: H90 Footswitch wiring spa
December 10, 2022 at 11:57 am
#167561
If you are unsure which aux switch will work, plug it in and try all of them until you get it. Restated, assign aux switch 1 and test. No worky? Assign aux switch 2 and test. Etc up to aux switch 6 until you get it.
Or just use the Learn function when assigning the switch and let the H90 figure it out.
